#15 | |
Drives: Scion FRS Halo White 2015
My luck is so bad, but I'll still be hopeful as you said. They've scanned and found cam issues and now fuel pump. Since they've scanned it, does that mean that they would've already detected my tune on the ecu or is it a different type of scan they need to look for to detect my tune? |
#16 | |
Drives: FT86
No the scan for codes and diagnostics works exactly the same on a tuned car as stock. They have to say try refreshing ECU, then they won't be able to due ecutek lock, or pull on cruise stalk and see map switching or read out the cvn number and compare it to the stock cvn not things they routinely do unless they are looking for tuned, but it's certainly possible to detect a loaded tune file |
| The Following User Says Thank You to steve99 For This Useful Post: | Roneezy (04-10-2017) |
#17 | |
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
#18 |
Feeling like thinking....
I could be wrong, but I think that anytime you take your car into the dealership, they enter the visit in their database. If one dealership denies warranty coverage based on your alteration of the car's ECU programming, they'll probably make a note of it and any other dealership would see that information when pulling up your car's records.
I hope things work out for you, but I'm kind of in the "you broke the warranty rules, so don't complain" crowd. Reflashing back to stock and lying to the dealership is a less than honorable path, Grasshopper.
Drive like everyone's life around you depends on it...
#19 | |
http://www.ft86club.com/forums/showt...highlight=Shiv |
| The Following User Says Thank You to Riftur For This Useful Post: | Roneezy (04-11-2017) |
#20 |
Well I got the car back and it seems to run fine.
All they did was clear the codes again and if it comes up just to go back to the dealership and they'll do whatever it is they did again. In the end nothing happened, I hope this is the end of it but that likely wont be the case.. |
#21 | |
#22 | |
I appreciate that. You and I are on the same boat lol. |
| The Following User Says Thank You to Roneezy For This Useful Post: | Riftur (04-12-2017) |
#23 |
Drives: Toyota GT86 Coupe Red (UK)
This always worries about ECU flash tunes. In a modern car, everything is controlled by software in the ECU. As a software developer I am thankful I do not work in the auto-motive department as the software quality controls and testing requirements are huge. Almost every line of code has to be documented, justified and defined for testing and potentially legal cases later on if they are suspected of causing death or serious injury... yes, it's that serious.
Then you hand over your car with multiple-million dollar developed and tested software to a bad street greasy tuning shop who flash it like it's an Android phone! Scary stuff. The downside is, if you fit aftermarket parts you might not get the full benefit from them without a flash. I believe you can have some parameters tuned more safely, but a full ECU flash sounds ... well... just dumb IMHO. If I was Toyota/Sion I would tell you to walk.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
| The Following User Says Thank You to paulca For This Useful Post: | Tcoat (04-17-2017) |
| Need advice - major problems with Hotchkis kit | GSX-R35 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 11-18-2016 02:48 PM |
| Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
| [Power Steering/Electrical/Warranty] Problems, could use some advice. | Ajax969 | Issues | Warranty | Recalls / TSB | 7 | 07-26-2015 07:01 PM |
| BRZ/FRS problems... | jdmgevo | Issues | Warranty | Recalls / TSB | 19 | 08-07-2014 10:54 AM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
