| Engine Swaps Discussion of engine swaps. |
Drives: 2015 FRS - FFR GTM
GM LFX 3.6L V6 Motor Swap
Update: Yes,, moving forward with a 2012-2015 Camaro LFX V6 swap.
I curious is anyone’s taken a look the GM Aluminum v6 LFX or derivative as a swap candidate?? HP is 325-335 TQ curve is nice and flat around 220 ish. Motor light (number I’ve seen is 345 but don’t know if it’s dressed at that weight), twin overhead cam with exhaust manifolds integrated into head. This last item is actually pretty slick. Normal exhaust would just be a down tube then out the back. If I’m not mistaken on the LF3 and LF4 (both 425+ HP) version they bolt the turbos directly to the head. Low mile LFX motors (Less than 10K) look to be around $2K and a 6 speed less than $1K. These are 2012-2015 Camaro setups. It’s drive by wire so the gas pedal is necessary as well. Might be cheaper to buy a whole wrecked car though and there are lots of them around. Oil pan might be an issue. The Camaro one is more of a rear sump but they are other that are more of a front sump,,, but might still need to be modified. I’ve spent a bit of time looking at the GTO pan straddling the cross member and rack in some of the pictures. As the V6 pan is shorter the trans would need to move forward a bit but it might fit. A custom pan is always an option but the cost would be a killer. Some of the Miata guys are putting these into their track cars and seem to like the results. I figured if it fits in a Miata should fit in a FRS. Line up of Motors,, the late model 3.6l LFX are in lots of GM cars https://en.wikipedia.org/wiki/GM_High_Feature_engine Last edited by gtpvette; 11-08-2018 at 03:32 PM. |
#2 |
in a Miata
2015 FR-S - One Day I'll Finish The Swap |
| The Following User Says Thank You to gtpvette For This Useful Post: | CxG (05-22-2017) |
#3 |
Drives: 2001 Impreza 2.5 RS
A lot of people consider this option but it always boils down to the only cost savings is on the engine and transmission. If you are going to go far enough to swap a whole drivetrain, at least do a V8
Colin Beck
| The Following User Says Thank You to MRS-Colin For This Useful Post: | hmong337 (03-21-2019) |
#4 | |
Certainly a valid point. I'll guess maybe a $5K difference for a similar mile motor and trans (your mileage may vary) but that should be about right. At the right price point installed I like the thought of this motor though. For a DD 325hp sounds like a like a lot of fun.
#5 | |
Drives: 2015 Firestorm FR-S
And if it was a DD maybe mpg would be something to consider? Not sure how much a real world difference would be in a light car but still, 5 mpg in a daily could be beneficial! Sent from my iPhone using Tapatalk
Not trying to make it perfect; I'm just trying to make it.
2015 Scion FR-S 6MT 2016 Subaru Crosstrek CVT 1972 Chevy C10 Shortbed 2018 Honda Civic Si Sedan |
#6 |
Only users lose drugs.
Drives: All the time
Another nice 60deg V6. Perfect match for this chassis.
| The Following User Says Thank You to venturaII For This Useful Post: | D_Thissen (04-10-2017) |
#7 |
Drives: frs
As long "bolt on" in the chasis with little to no modification im sold.
#8 | |
[insert cool phrase here]
Drives: BRZ Premium
The though did come to me, but only if it was like a bolt on and the price was way cheaper than V8 or a tad ballpark for a FI kit.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#9 |
After looking at more oil pans then I care to mention,, I came across this. It's from a Holden but a bit older V6 than the LFX. Bolt patten looks the same though. If it works,,, it's the GTO pan for this V6 (front sump).
| The Following User Says Thank You to gtpvette For This Useful Post: | venturaII (04-10-2017) |
#10 |
I'll add these as well. They show the stock motor mounts. The question is,,, would they line up right above the cross member. Note the center picture shows the Camaro rear sump pan,,,, which wouldn't work. The mounts seem to be right about the middle cylinder.
#11 |
As I'm thinking about it ,, at 325HP are the axles and rear end OK??? Could the cooling system handle 325HP with AC and the heat of South Florida??? Also,,, would a new driveshaft be necessary??? Could you take the Camaro drive shaft and put a FRS rear end adapter on it or visa a versa??
#12 |
Drives: Stock
To save weight the transmission is almost identical to ours. I even wonder if a cheap adapter would save on this swap and the motor weighs almost 30lbs lighter then the fa20 at least this is what I have came up with! Yes I have been considering this for a long time and if I can swing it it's on my list!!! Lighter engine and 100 more hp! Been on the Camaro forums and I believe they have got the motor close to 300whp. Plus nice flat torque band.
#13 |
Drives: BRZ Premium
In reality anything is possible with the time and money.
#14 |
Too bad searching on LFX reveals nothing. Found this searching on 'Crossmember'
http://www.ft86club.com/forums/showt...smember&page=6 Mods close this thread pls. Thanks!!
| Should I have just got a new motor? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 12 | 07-31-2017 08:51 PM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 03:39 PM |
| K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 07:51 PM |
| Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 10:28 AM |
| MOTOR UNION | David | Southern California | 0 | 06-22-2013 02:32 PM |
