Old 03-31-2017, 02:11 PM   #1
Kris86
Kris86's Avatar
Drives: RHD Gt86
Intake Cam Timing advanced 20 Degrees at IDLE
Hey guys, as the title asks, how do I go about checking the AVCS timing? Can it be adjusted ?
My car has the intake cam advanced 20degrees at idle :-S
Would truly appreciate anyone helpglglglgl
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 03-31-2017, 06:03 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
How are you measuring that it's 20 degrees at idle? If it's via logging, what are you using? Which bank etc? Same on both? Does it noticeably feel different as it should? It would also likely throw a CEL.
Does it move around if you use the accelerator?
.: Stealth 86 :.
Kodename 47 DJ:
Kris86 (03-31-2017)
Old 03-31-2017, 09:28 PM   #3
Kris86
Kris86's Avatar
Drives: RHD Gt86
I'm doing a idling datalog through ECUTEK for my tuner.
When he go it the first thing he noticed was that the INTAKE cam is at advanced 20 degrees :-/
No engine light ever cam on, and that the weird part
it jumps around when u touch the throttle, but it stays in that particular region, while the others stick around -0 - 1
I think also it was on the left head, I'll have to back check if it's both headsgl
Old 04-10-2017, 10:53 AM   #4
Kris86
Kris86's Avatar
Drives: RHD Gt86
bump! need some help guys.
cant figure out what is causing this up to now. car wont idle on its own even.
it also sounds like a extreme unequal length header, meaning missing badly.
Old 04-10-2017, 11:57 AM   #5
steve99
Drives: FT86
As Kodename47 said weird it not throwing and CEL codes and CEL light
AFAIK cams should all be at 0 at idle.
If just one is reading 20 then its possible that cam sensor is bad. but should throw code due correlation error.
If its now idling like crap mabe the cam actuator is stuck, but again you would expect cel codes/light.
mabe look through these TSB
11-130-13R : Difficulty Starting, Rough Idle, Cam Position, Misfire
http://www.ft86club.com/forums/attac...1&d=1375302652
02-132-12 : DTCs Relating to the AVCS (Active Valve Control System)
http://www.ft86club.com/forums/attac...0&d=1352490977
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Kris86 (04-10-2017), strat61caster (04-10-2017)
Old 04-10-2017, 01:15 PM   #6
Amputechture
Drives: 2014 BRZ
You have a JDL kit correct? I am running their kit and the downpipe touches my passenger side Cam Angle Sensor. Lots of others have had this issue, I've wrapped it in a loom and heat tape. Perhaps this could be a culprit?
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
Kris86 (04-10-2017)
Old 04-10-2017, 01:31 PM   #7
Kris86
Kris86's Avatar
Drives: RHD Gt86
I too thought it could be the cam solenoids, so I swapped the intake cam solenoids to see if it would move the problem over to the other head, but the issue is still on the left head. Same exact outcome
I will definitely read through the TSB's... I'm taking any advice that comes to me at this point
Old 04-10-2017, 01:33 PM   #8
Kris86
Kris86's Avatar
Drives: RHD Gt86
Yes I do have the JDL kit, I did notice that the down pipe runs rather close to that sensor so I did to a little Fab, but the issue is on the other head
Old 04-10-2017, 01:46 PM   #9
Ragin Gti
Drives: '15 Subaru BRZ
Have you had the timing chain off of the car?
Ragin Gti is offline   Reply With Quote
Old 04-10-2017, 01:55 PM   #10
Tokay444
What is the tune commanding?
Old 04-10-2017, 03:43 PM   #11
Kris86
Kris86's Avatar
Drives: RHD Gt86
Yes I just did a complete engine rebuild, changed rods, pistons, valves, springs and retainers
Old 04-10-2017, 03:47 PM   #12
Kris86
Kris86's Avatar
Drives: RHD Gt86
Not sure, I am doing F&G with delicious
Old 04-10-2017, 04:04 PM   #13
steve99
Drives: FT86
haha, that changes things :-).
Still strange the ECU doesn't complain if its commanding zero and the sensor reads 20, that's assuming that's whats happening.
Old 04-10-2017, 04:08 PM   #14
Kris86
Kris86's Avatar
Drives: RHD Gt86
Yup! Same thing we all are thinking :-S
No codes makes it so much harder
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 12:39 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
AVCS tuning Turdinator Software Tuning 9 11-24-2015 02:31 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 02:48 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
