| Engine Swaps Discussion of engine swaps. |
#15 |
Amateur Drifter
Drives: '13 FRS
Reserving spot #3. Love the work you did on the 2J swap! I don't need ABS or AC, drift car life....
| The Following User Says Thank You to gatorbushmen For This Useful Post: | Pure Automotive (03-30-2017) |
#16 |
Drives: 2013 Scion FRS
How much would this kit run? Or how much is the 2JZ kit? I assume they'd be similar in pricing. My friend has a totaled Camaro which hapoens to have a working LS1 in it still.
"Chasing speed with patience" |
#17 |
Drives: 2013 Ultramarine FR-S
2JZ kit is almost $6000. This should be priced comparably.
#18 |
#19 | |
Pure 2JZ Motec Plug and Play
#21 |
Drives: 2017 WR BLUE BRZ
I need this asap, so if you're taking deposits, I'm ready to place the order.
| The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | DustinS (03-30-2017), Pure Automotive (03-30-2017) |
#22 | |
Drives: 2013 FRS Whiteout
There's a list of questions for building the engine side harness as far as what sensors, etc. Make sure you're familiar with what your engine will have on it sensor and accessory wise. |
#23 | |
#24 |
Part 1 !
[ame]http://youtu.be/Axt_AiE6wg8[/ame] |
| The Following 4 Users Say Thank You to Pure Automotive For This Useful Post: |
#25 |
Eagerly awaiting part 2 and 3!
#26 |
What works for 2js works for lsx
![]() [ame]http://youtu.be/kcIUkmbJMsU[/ame] |
| The Following 3 Users Say Thank You to Pure Automotive For This Useful Post: |
#27 |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Pure Automotive (04-09-2017) |
#28 |
Drives: 2001 Impreza 2.5 RS
Has pressure compensation etc been built in? I know this can be a hassle since GM used a few different sensors etc.
Colin Beck
| Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 07:11 PM |
| Motec M1 Plug N Play | FullBlown | Forced Induction | 89 | 05-09-2014 01:45 PM |
| The New Consolidated Install Thread @Pure Automotive Performance, FT86 Specialists! | Pure Automotive | Mid-Atlantic | 14 | 09-26-2013 11:28 PM |
| **The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive | Pure Automotive | Brakes, Suspension, Chassis | 1 | 02-06-2013 03:32 PM |
| *Pure Automotive Performance: Project Whiteout FRS Build Thread* | Pure Automotive | Member's Car Journals | 6 | 01-18-2013 12:34 PM |
