Old 03-29-2017, 08:40 AM   #127
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by FR-Sky View Post
The reason why i asked becus my car tend to oversteer =[
i dont know if i go too fast or i throttle too early....
I have -3 camber front/ -2.5 rear
0 toe front, 0.05 toe in rear
255 tires
22mm front sway bar/ stock rear
Yes, it oversteer between mid corner and exit,,if I throttle the car swing and traction control kick in. The only time I can really throttle is when the car most straight.
It is factory setting 35psi all around.
It is TEIN flex Z, indy 500 , 255/40/17 square.
When I turn the traction control will kick in, and it is hard to throttle unless the car almost full straight.
I know it is not kicking in from too much understeer becus i know my tail swing little bit and the TC try to save it.
Yes I do have 22mm front sway, and I thought it would fix it as well.
My ride height is Flex Z standard, 0.8 inches front, 0.7 inches rear.
Damper is from hard, front 5, rear 8.
Unless something is broken, this must be a tire grip issue. Sometimes even very good/grippy tires can "age out" in surprising ways. This happened with the Michelin Pilot SuperSports on my FD. Initially fine, but after ~2 years and maybe 10-12k miles (still more than half tread depth remaining) the car became well nigh undriveable. The rears would spin *ridiculously* easily and when they did the car went dead sideways (no residual sliding grip). It took me a while to convince myself because of how good those tires initially were and not being that old or anywhere near the treadwear indicators, but replacing the tires 100% fixed it.
FR-Sky (03-29-2017)
Old 03-29-2017, 11:07 AM   #128
Icecreamtruk
Drives: Track preped NA FRS
You know what, dont do anything else to your setup. Go to an empty space (track or parking lot, industrial zone, whatever, just something big and empty), disable all nanies (5sec push on track control should work, you could do the pedal dance if you know how to), and then do what you would do to take the turn where you think your rear is stepping out. If it starts stepping out, dont correct it, let it spin, all the way. Im still not convinced you are seeing oversteer. Dont do anything else you wouldnt be doing before, dont try to force the spin (which you can in any car, any setup), just do what you were doing, similar speeds if possible, make sure there is enough space, and just see what happends.
I honesly think spending more money before having a clear sight of what your problem is, its a waste of money and time. Also, disable those nannies already, you should not be driving on track with them, dont depend on them, it will not make you a better driver by any means.
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
FR-Sky (03-29-2017), strat61caster (04-17-2017)
Old 03-29-2017, 09:15 PM   #129
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I bought my tires last Christmas...fairly new about 3-4k miles. 1 track day, and all daily and mountain. I am not gonna change until end of this Christmas or
3-5 tracks days cus budget wise lol =[
I am going to try re-71 or rs 3 next time. Thanks for sharing~
FR-Sky is offline   Reply With Quote
Old 03-29-2017, 09:16 PM   #130
FR-Sky
FR-Sky's Avatar
That would be good idea, but first i need to find a empty space...
I didn't fully turn off my TC when I am doing track cus I was afraid too.
The Following 2 Users Say Thank You to FR-Sky For This Useful Post:
churchx (03-31-2017), Icecreamtruk (03-30-2017)
Old 03-29-2017, 10:54 PM   #131
cjd
cjd's Avatar
Drives: 2017 BRZ
AutoX test-n-tune. Or even just an AutoX event or ten. If you pay attention, it can teach you a ton about your car and your driving at the limit of the tires/suspension/surface.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Icecreamtruk (03-30-2017), strat61caster (03-30-2017)
Old 03-30-2017, 08:05 AM   #132
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The nannies kick in to save you well before you need saving. I would not try to judge a car's balance with the nannies on. (And I would make sure I was testing in safe conditions when I turned them off and pushed the car)
Twinz is offline   Reply With Quote
The Following User Says Thank You to Twinz For This Useful Post:
Old 03-30-2017, 12:51 PM   #133
ZDan
ZDan's Avatar
Drives: '23 BRZ
RE71's are great but will be short-lived. My rears lasted <1000 miles and one track day on the FD! I've gotten tremendous (relatively) life out of RS3s on the S2k.
Weird. I daily an S2000 with similar power/weight and unless you are really screwing up, getting on the throttle exiting a corner results in understeer, not oversteer. Even with ludicrous power (~550hp) in the FD, up to incipient wheelspin getting on the throttle exiting a corner widens the line (aka understeer).
I still think for you to get power-on eversteer on corner exit, assuming reasonable inputs (i.e. easing on the throttle rather than just nailing it), unless you are making way more than stock horsepower, it must be the tires.
Are they the "Firehawk Indy 500" or the "Firehawk Wide Oval Indy 500"? I wonder how old they were when you bought them?
Old 03-30-2017, 10:35 PM   #134
FR-Sky
FR-Sky's Avatar
I believe i have the Firehawk indy 500, 255/40/17, and they produce at the same year 2016 i believe. My car is pretty stock, just header, intake and full exhaust system w/e85 custom tune produce about roughly 230HP.
All the parts are done in trusted professional shop, I mean if something weren't right or broken, they would tell me right lol?
I think my solution here is to find someone who are experience on track with the 86 to see if they can point out the problem.
Thanks!
Old 04-14-2017, 10:50 PM   #135
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Why was my toe so wonky? Last alignment was ~1k miles ago in December.
Originally Posted by humfrz
I'm old and lazy
Old 04-17-2017, 05:33 PM   #136
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Sorry to side track...did you notice your feeling more "floaty" or easily turning after going zero toe? I have similar alignment specs as you when I first lowered my car but not it feels like the steering is too loose and less grippy. I have a doubt that it's because I requested to have the toe set to 0.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 04-17-2017, 06:51 PM   #137
Clipdat
Proud of BOXER
Clipdat's Avatar
Unfortunately I've only driven on it a few miles around town since the alignment, but I have not noticed any abnormal steering feel compared to before. Everything feels "really good" right now, for lack of a better term.
I will have to log some more miles on it including some spirited driving and then I'd be happy to follow back up with you.
I'm old and lazy
ap5512 (04-18-2017)
Old 04-17-2017, 10:39 PM   #138
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
toe out or zero toe will make turn in easier, and feel a bit less stable at higher straight line speeds, but more stable in corners.
toe in gives more straight line stability.
JeremyR is offline   Reply With Quote
The Following 2 Users Say Thank You to JeremyR For This Useful Post:
ap5512 (04-18-2017), Clipdat (04-18-2017)
Old 04-18-2017, 11:34 PM   #139
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What are you using to get those caster numbers?
Intent > Content
Old 04-19-2017, 03:29 AM   #140
Clipdat
Proud of BOXER
Clipdat's Avatar
I have these: http://www.raceseng.com/cascam-caste...ubaru-brz-2013
Which, now that I read the page, adds one degree which gets you 7 degrees max it says.
So, I'm honestly not sure. I would have to send an email to the shop inquiring.
I'm old and lazy
solidONE (04-25-2017)
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 07:30 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-10-2012 12:36 AM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 01:29 AM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 12:41 PM
where to get alignment? FML Hawaii 2 08-08-2012 02:36 AM
