Old 03-24-2017, 11:00 PM   #1
Beem97
Drives: 1997 BMW 328is
Help Much Appreciated!
Hello everybody!
My name is Nate, and I am a high school engineering student from Illinois. I have a passion for engineering (especially in the automotive field) and have a school project that I am working on. My team and I are exploring more affordable press technology in order to develop and alternative for hydraulic presses that the home mechanic can use. If you wouldn't mind taking my survey, it would help us greatly!
Sorry if this is the incorrect place to post this. My topic doesn't seem to have a fitting category.
Thanks,
Nate
Here is the Link: https://docs.google.com/forms/d/e/1F...rm?usp=sf_link
Beem97 is offline   Reply With Quote
Old 03-24-2017, 11:09 PM   #2
Survey completed.
You may want to reword your original post as it is deceiving based upon your survey questions. You really are not looking for an "alternative" to a hydraulic press but reduced cost hydraulic press
There have ben mechanical presses for several hundred years.
I could run down to the local auto parts store and pick one up for about $100 today. They haven't even changed much.
Old 03-24-2017, 11:33 PM   #3
Originally Posted by Beem97 View Post
Hello everybody!
My name is Nate, and I am a high school engineering student from Illinois.]
Hello Nate and welcome to our forum.
I think @Tcoat pretty well summed it up.
A simple mechanical press would pretty much by fine for your average shade tree mechanic.
It's smart of you to do a market survey before developing something very few people would have a use for.
Good luck with your studies .......
Tcoat (03-24-2017)
Old 03-24-2017, 11:45 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Sadly, my problem is less with COST, and a lot more to do with SPACE.
Survey completed anyway.
The Following User Says Thank You to cjd For This Useful Post:
Tcoat (03-24-2017)
Old 03-24-2017, 11:46 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
Get some 3/4 or inch steel plate
Get threaded rod in whatever diameter you choose (check the load capacity of different sizes to get your rough capacity)
Drill holes in plate near the corners
Tap-tap-tap-a-roo
Use high load nuts to draw the plates together to press things. Press capacity may be less than threaded rod capacity due to having to use the nuts to draw the plates together. Should still give you a few tons depending on your configuration.
Use large washers, maybe an oil-lite bushing sandwiched between them to prevent ****ering of the surface where the nuts rotate against the plate
Price of threaded rod/steel plate/drill/tap (and an extra when you break the first one off flush)
::edit
Oh hell, just watch this guy
If you are into engineering/machining/metal work subscribe to this guy, he is a bit rough around the edges and the canukistan language can be strange
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Tcoat (03-24-2017)
Old 03-24-2017, 11:47 PM   #6
Also you need to define "more affordable" since a decent looking 12 ton press can be bought for $84 on Ebay this very minute.
I am not criticizing here and it is a cool engineering project I am just suggesting some points you could clarify to assist in your research. It is very important to have clear goals and mission statements for this sort of thing.
Old 03-24-2017, 11:50 PM   #7
Tap-tap-tap-a-roo
Almost a word for word description of my home made press back in 73. Right down to the broken rod (I broke two though).
OH, and don't leave it out in the weather over a winter. They become a nice solid door stop by spring if you do.
Old 03-24-2017, 11:50 PM   #8
DJCarbine
Thupercharged
DJCarbine's Avatar
Those arbor type presses are handy and easily found, for a few hundred (or less) you can also get a 12 ton hydraulic press that works fine for removing wheel bearings from hubs from your local horrible freight
2013 FRS
Vortech V3 11psi
Tcoat (03-24-2017)
hydraulic press
My 14' FRS Appreciated In Value!!! Phantobe Scion FR-S / Toyota 86 GT86 General Forum 21 01-18-2017 08:13 AM
OFT first pull log feedback appreciated Red Barchetta Software Tuning 4 07-12-2015 09:45 PM
My first track experience (feedback appreciated!) TheLaughingMan Tracking / Autocross / HPDE / Drifting 29 03-12-2014 06:26 PM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 04:53 PM
Any help much appreciated! FaNtaSy Engine, Exhaust, Transmission 6 08-23-2013 11:13 AM
