Drives: 2017 ISM PP BRZ
STI Brembo Calipers the Same Size as BRZ Brembos?
Yes. Even tho the part numbers for pads are different, I found that my nearly new track pads from my 2015 STI are direct fit for the 2017 Performance Pkg BRZ, so there's about $400 I can put to use elsewhere!
| The Following User Says Thank You to JSube For This Useful Post: | Kenny_LongWrench (03-22-2017) |
#2 | |
Drives: Subaru BRZ / Toyota 86 Experts
#3 | |
#4 |
Drives: between cars...
I was just posting about this looking for more info too...
http://www.ft86club.com/forums/showthread.php?t=116759 The dealer said that the rear pads have the same part numbers but the fronts are different. Are the brake pads designed differently based on their clock position? |
| The Following User Says Thank You to imnotsureaboutbrz For This Useful Post: | JSube (03-21-2017) |
#5 |
Drives: Legacy GT
I wouldn't be surprised if they use the same pad shape, most of the oem brembo 4-pots do.
#6 | |
Either I wasn't clear or you misunderstood- I was talking about interchanging the pads between the 2 cars not the calipers. Just confirmed fitment with GLoc, imnotsureaboutbrz John |
#7 | |
Brembo calipers may be different but a lot of the pad shapes are shared between various Brembo calipers. |
#8 |
Frosty Carrot
Drives: The Atomic Carrot
While many Brembo setups use similar pad shape and caliper type... don't ignore Mike's comment ("All calipers are vehicle application specific").
The piston configuration is unique to each vehicle. Lots of things go into choosing the bore diameter(s), location(s) and features. Your master cylinder displaces a specific volume of fluid and is designed to have a working pressure range. The vehicle's front/rear weight bias, total weight, and OEM brake bias will also dictate the piston bore(s) total cross-sectional area. The rotor and pad thickness will affect the max excursion of each piston. The force distribution on the pad will determine the modulation behavior (including the assist and anti-lock dynamics). You can also delve into exotic materials and venting for pistons, if you expect ultra-high temperatures. Also, the centerline diameter of the pistons will change with rotor size, since calipers are developed to accommodate a range of rotor ODs and thicknesses.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | JSube (03-22-2017) |
#9 | |
![]() The OP messaged us to get clarification on pads and calipers. |
| The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post: | JSube (03-22-2017), Shankenstein (03-22-2017) |
#10 |
Ummmm Mike checking in.
Pads are interchangeable, calipers are not. In fact, the OEM sized pads can also be used in the CSG x Brembo BBK, although the CSG x Brembo kit can also accept larger (thicker) pads. If you're unable to source larger pads, OEM sized pads will always work in a pinch. |
#11 | |
#12 | |
#13 |
#14 |
| WTB Brembo Calipers Miami, Fl | Danny3602 | Want-To-Buy Requests | 3 | 12-15-2015 05:06 PM |
| STI Brembo Calipers - Anyone tracking these yet? | AyJay | Tracking / Autocross / HPDE / Drifting | 4 | 10-29-2014 03:50 PM |
| 05 REAR STI BREMBO CALIPERS | subyboy | Brakes, Suspension, Chassis | 19 | 04-15-2014 08:07 PM |
| WTB STi Brembo calipers | cammaxon | Want-To-Buy Requests | 1 | 01-28-2014 07:04 PM |
| FS REAR 05 STI BREMBO CALIPERS | subyboy | Brakes, Suspension, Chassis | 9 | 01-01-2014 03:46 PM |
