Old 03-17-2017, 08:11 AM   #1
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
STI Brembo Calipers the Same Size as BRZ Brembos?
Yes. Even tho the part numbers for pads are different, I found that my nearly new track pads from my 2015 STI are direct fit for the 2017 Performance Pkg BRZ, so there's about $400 I can put to use elsewhere!
JSube is offline   Reply With Quote
The Following User Says Thank You to JSube For This Useful Post:
Kenny_LongWrench (03-22-2017)
Old 03-20-2017, 02:10 PM   #2
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Many Brembo OE calipers have similar pad fitments (that's what makes Brembo so cool), but all calipers are vehicle application specific. The BRZ PP Brembos may be the same OE type of caliper as the STI, but are configured differently (one is trailing and the other is leading). Please do not interchange the two.
CounterSpace Garage is offline   Reply With Quote
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
DustinS (03-20-2017), JSube (03-21-2017), SkAsphalt (03-20-2017)
Old 03-21-2017, 01:46 PM   #3
JSube
JSube's Avatar
Oh hell, damn, nooo! You're right, of course- STI front calipers were trailing at 3 o'clock, BRZ is leading at 10. But help me out- are you saying a pad that looks symmetrical and has the same chamfer cuts at both lower corners is somehow different in other ways?
Old 03-21-2017, 01:55 PM   #4
imnotsureaboutbrz
Drives: between cars...
I was just posting about this looking for more info too...
http://www.ft86club.com/forums/showthread.php?t=116759
The dealer said that the rear pads have the same part numbers but the fronts are different. Are the brake pads designed differently based on their clock position?
imnotsureaboutbrz is offline   Reply With Quote
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
JSube (03-21-2017)
Old 03-21-2017, 02:03 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
I wouldn't be surprised if they use the same pad shape, most of the oem brembo 4-pots do.
jamal is offline   Reply With Quote
Old 03-21-2017, 04:08 PM   #6
JSube
JSube's Avatar
Hey Mike-
Either I wasn't clear or you misunderstood- I was talking about interchanging the pads between the 2 cars not the calipers.
Just confirmed fitment with GLoc, imnotsureaboutbrz
John
Old 03-21-2017, 06:25 PM   #7
CounterSpace Garage
Hey Mike-
John
Brembo calipers may be different but a lot of the pad shapes are shared between various Brembo calipers.
Old 03-21-2017, 09:22 PM   #8
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
While many Brembo setups use similar pad shape and caliper type... don't ignore Mike's comment ("All calipers are vehicle application specific").
The piston configuration is unique to each vehicle. Lots of things go into choosing the bore diameter(s), location(s) and features.
Your master cylinder displaces a specific volume of fluid and is designed to have a working pressure range. The vehicle's front/rear weight bias, total weight, and OEM brake bias will also dictate the piston bore(s) total cross-sectional area. The rotor and pad thickness will affect the max excursion of each piston. The force distribution on the pad will determine the modulation behavior (including the assist and anti-lock dynamics). You can also delve into exotic materials and venting for pistons, if you expect ultra-high temperatures. Also, the centerline diameter of the pistons will change with rotor size, since calipers are developed to accommodate a range of rotor ODs and thicknesses.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
JSube (03-22-2017)
Old 03-21-2017, 10:30 PM   #9
CounterSpace Garage
Mike has his own handle. @CSG Mike
The OP messaged us to get clarification on pads and calipers.
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
JSube (03-22-2017), Shankenstein (03-22-2017)
Old 03-21-2017, 11:26 PM   #10
CSG Mike
CSG Mike's Avatar
Ummmm Mike checking in.
Pads are interchangeable, calipers are not.
In fact, the OEM sized pads can also be used in the CSG x Brembo BBK, although the CSG x Brembo kit can also accept larger (thicker) pads. If you're unable to source larger pads, OEM sized pads will always work in a pinch.
Old 03-22-2017, 07:58 AM   #11
JSube
JSube's Avatar
Thanks, Shakenstein. My original comment was about pads only, not calipers. On track next week, weather permitting!
Old 03-22-2017, 01:42 PM   #12
imnotsureaboutbrz
awesome, I see some Winmax W2 or W3's in my future...
Old 03-22-2017, 02:31 PM   #13
CSG David
CSG David's Avatar
David here. If you are looking at the CSG x Brembo GT kit, we have packaged it with a very good brake pad.
Old 03-22-2017, 02:35 PM   #14
imnotsureaboutbrz
I appreciate the offer! but the Brembos on the car are working fine But I will be putting in a order for the pads, and maybe your exhaust...
WTB Brembo Calipers Miami, Fl Danny3602 Want-To-Buy Requests 3 12-15-2015 05:06 PM
STI Brembo Calipers - Anyone tracking these yet? AyJay Tracking / Autocross / HPDE / Drifting 4 10-29-2014 03:50 PM
05 REAR STI BREMBO CALIPERS subyboy Brakes, Suspension, Chassis 19 04-15-2014 08:07 PM
WTB STi Brembo calipers cammaxon Want-To-Buy Requests 1 01-28-2014 07:04 PM
FS REAR 05 STI BREMBO CALIPERS subyboy Brakes, Suspension, Chassis 9 01-01-2014 03:46 PM
