Old 03-14-2017, 11:59 PM   #1
bass_114
bass_114's Avatar
Drives: wrb brz
Flasher lights stuck on Tom's tail lights
Hey guys so tonight we got hit with a ton of snow in my area and driving was less then fun as they never plowed with over 4 ft of snow now.
So heres the issue while reving because wheelspin my blinker on the passenger side stayed stuck in on position. And now the blinker stuck does not do anything. I tried turning off the engine restarting nothing,stays lit, i tried unplugging the battery which turns it off obviously but as soon as i plug it in again it turns back on.
Now left the battery unplugged just so it does not drain but wondering how to fix my flashers so ppl don't think I'm continuously turning right lol.
bass_114 is offline   Reply With Quote
Old 03-15-2017, 12:44 AM   #2
You might consider checking (replacing) the flasher.
You may have a burnt out bulb on that circuit (front or rear).
Bubba suggests to bang on the dash and tail light housing real hard .....
@Ultramaroon ...... how about a little help here .....
bass_114 (03-17-2017), Ultramaroon (03-15-2017)
Old 03-15-2017, 12:53 AM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Bad flasher relay. Ask me how I know 😉
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 03-15-2017, 01:13 AM   #4
Because you read my post ....... ??
Spartarus (03-15-2017)
Old 03-15-2017, 01:23 AM   #5
Jeebus, don't go banging on anything. If it's not the switch on the stalk then I'd go with what BigFatFlip is saying. Makes perfect sense.
Old 03-15-2017, 02:25 AM   #6
bass_114
bass_114's Avatar
Drives: wrb brz
damn thanks for the quick help! Any bad effects if i reinstall the stock original relay until the new relay comes in at least to have flashers lol...I mean other than the hyper flash?
Old 03-15-2017, 02:55 AM   #7
I guess so. The circuit's fused but why would you want to drive around with your turn signal stuck on? You're not @humfrz' age.
Cole (03-15-2017), Tcoat (03-15-2017)
Old 03-15-2017, 03:07 AM   #8
Hey, leaving your turn signal on has it advantages ........ it backs off the jerks behind you ....... because they are never sure what you're gonna do ......
Cole (03-15-2017), Ultramaroon (03-15-2017)
Old 03-15-2017, 02:09 PM   #9
Pro tip
humfrz (03-15-2017)
Old 03-15-2017, 02:20 PM   #10
Depend on what blew your other flasher. You could be right back to it stuck on.
Old 03-15-2017, 03:20 PM   #11
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
The original flasher relay would not work with the Tom's, would it?
That's why they include a specific different one with the lights, no?
I have Tom's too so i'm curious of the answer to this in case it ever happens to me. I would assume it's the relay, but would assume you'd want to order or somehow obtain another Tom's one to ensure everything works properly and you don't short anything else out.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 03-15-2017, 03:35 PM   #12
Oh, jeez. Now I'm up to speed. I didn't understand OP's question about reinstalling the FACTORY relay.
The flasher included with the Toms is designed to work with the much lower current draw of the LED turn signals. The factory relay "hyperflashes" because it can't tell the difference between LEDs and a burned out bulb. That's all.
bass_114 (03-17-2017), SLVRSRFR (03-15-2017)
Old 03-17-2017, 11:34 AM   #13
bass_114
bass_114's Avatar
Drives: wrb brz
thanks! so for now will roll with hyper flashers, hopefully this solves it will update the thread
FS/FT: Helix K Shade Tail Lights (Tribar Tail Lights) seeknowmoree Exterior Parts (Aero, Lighting, Etc.) 1 09-03-2016 01:32 AM
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 02:19 PM
OEM Tail Lights and OEM Flasher Relay $120 OBO BG.Ghost8 Canada Classifieds 0 08-12-2014 12:56 PM
ok to use flasher unit from TOM's JDM US tail lights for LED int/ext upgrades? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 1 08-29-2013 01:04 PM
