Old 03-11-2017, 12:15 AM   #1
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
Subaru BRZ With e85 Flex Fuel Kit Not Starting In Cold
Today after some snow and it being 32 degrees outside, my Subaru BRZ is refusing to start. It's an automatic. It has the moto-east flex fuel kit installed and tune. I tried starting the ignition over 10 times, but it's just not starting.
Is this typical for cars with e85 and this flex fuel kit?
I e-mailed Moto East and I'm waiting for a response.
Will they send me an updated tune, or what do I have to do to get my car to start? Should I put some regular gasoline in it or something?
The ethanol content is above 80. Any ideas?
Here is a video of it,
[ame="https://www.youtube.com/watch?v=7pfJuKF_t7s"]Subaru BRZ E85 Cold Start Problem With Ignition Not Starting After Snow - YouTube[/ame]
morswestford is offline   Reply With Quote
Old 03-11-2017, 12:27 AM   #2
Boomerang
86
Boomerang's Avatar
Lots of info on this forum about it such as;
http://www.ft86club.com/forums/showthread.php?t=84644
People add regular gasoline to fix the problem, should be OK for you as you have flex fuel
Old 03-11-2017, 01:23 AM   #3
phrosty
Winter blend E85 is typically ~E60 tops from what I've seen. Curious how you have >E80 when it's 32 degrees out!
phrosty is offline   Reply With Quote
Old 03-11-2017, 01:36 AM   #4
morswestford
thats what i figured, thx. ill try adding regular gasoline tomorrow.
Old 03-11-2017, 01:37 AM   #5
morswestford
well yesterday i went and filled my tank completely with e85 and that's what it went to after i did so. Omega Fuels, in Southampton PA. Maybe they had more ethanol in it.
Old 03-11-2017, 09:52 AM   #6
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
omega fuels has the best blend of e85 around our area. I'm from philly too, but I usually fill up at the scam shell station near Chinatown just for the convenience.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 03-11-2017, 07:25 PM   #7
morswestford
I messaged Omega Fuels on Facebook and they apologized to me. They said their winter blend is not suppose to be above 80, and mine went to 88. My tank was on empty when I filled it all up, so 99% of the fuel came from their pump. Seems like I got too much ethanol.
Very strange.
Old 03-11-2017, 09:03 PM   #8
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
In Indiana we have high blends as well. I filled up yesterday with E77.
ajcarson11 is offline   Reply With Quote
Old 03-11-2017, 10:22 PM   #9
morswestford
update
Today i went and filled my tank with 6 gallons of regular gasoline (87 octane). The rest of my tank has e85, so it's 50% regular gas and 50% e85. Omega Fuels recommended me to dillute the e85 with regular gasoline and that's exactly what I did.
It still doesn't start.
I messaged Moto-East because it's their flex fuel kit and tune, and I'm waiting for a response. At this point I have no idea what to do. My car still doesn't start.
I opened the engine bay and saw the Zeitronix box flashing yellow. Does anyone know if this is normal , or is something wrong with the moto east flex fuel it, or possibly the tune? I have no clue what the problem is now. This is really weird.
Also the ethanol content anylyzer only went down from e88 to 83. So i'm not sure how accurate that is since half of my engine is regular gas. That seems to be way off. Shouldnt it be way below 80 by now? Strange.
[ame="https://www.youtube.com/watch?v=G6UjiWkvzvM"]March 11, 2017 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=L-QgdKYLysw"]March 11, 2017 - YouTube[/ame]
Old 03-11-2017, 10:56 PM   #10
Teseo
Drives: frs
Best way is to drain all ethanol via priming fuel pump and fill the tank with gasoline and give it a try
Old 03-11-2017, 11:52 PM   #11
ajcarson11
You did fill the tank with 93, but the fuel that is in the lines is probably still pure ethanol. You could carefully disconnect the fuel lines and prime the pump a bunch to drain the lines. Hmm.
Old 03-12-2017, 01:50 AM   #12
Dipstik-sportech
Dipstik-sportech's Avatar
Betting it's flooded now and the plugs are soaked.
Old 03-12-2017, 03:01 AM   #13
OR, @morswestford , do it the old fashioned way ....... spray diethyl ether into the intake, which should allow the engine to start and run, to pull the ethanol through the lines to get to the gas mix.
CAUTION: Don't be looking at the intake real close if the engine backfires ......
Bubba in for humfrz
Old 03-12-2017, 10:43 AM   #14
morswestford
Bubba in for humfrz
interesting idea, how do i easily open the air intake to spray that?
e85, engine start, flex fuel, moto east, subaru brz
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
Flex Fuel cold start stumble post_break Software Tuning 12 04-02-2014 02:40 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
