#15 |
Senior Hoonigan
Drives: 2016 Hot Lava 6MT FR-S
Is that really 98 octane? is that calculated as (r+m)/2?
I know in Vietnam everything says 98 octane, but it's RON (research octane) which only calculates the isooctane, not the heptane... rather than RON+MON/2 (which is how we calculate in US/CAD). |
#16 |
Track Junkie
Drives: Faster than the Stig!
Shell 93, im trying out mixing 93 with a bit of ms109 to see what happens.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| The Following User Says Thank You to track_warrior For This Useful Post: | Hanzo (06-29-2012) |
#17 | |
Senior Rocket Bunny
Drives: 1982 XX KE70
Regular is 91 then there is 95 premium and ultimate is 98..... Caltex: ![]() BP: Apology for size...
#18 |
Drives: S2000
normal UL is 95 here in the UK, but find my (performance) cars always run better on 99 octane (Shell V Power, Tesco Momentum99) so will be treating her.
#19 |
Drives: Forester 2007, BRZ Limited '13
NorCal, only Chevron 91 octane from a set of stations I normally use. Occasionally would use Valero if no Chevron around.
I found Shell gas to be, how do I put it... watery - burns out quick, lesser mpgs on our family car. And I can feel that I'm getting less power out of the engine with Shell too (not BRZ, cause I avoid Shell for those reasons). Maybe I'm paranoid. 76 - actually found that regular gas from them can cause detonation (happened to me on several occasions with rental cars). So, I avoid 76 as well, regardless of grade.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#20 | |
Senior Hoonigan
America and Australia use two different methods for grading their fuel. Australia is RON, America is RON+MON/2. The highest "octane" fuel readily availible in America is 92 which is equivilent to our 98RON. So it looks like your 98 is equivalent to the US 92. |
#22 | |
Senior Rocket Bunny
In Australia, from October 2006, Shell and Coles Express re-branded Optimax to V-Power (98 RON). V-Power Racing, the ultra-high performance variant has a rating of 100 RON although Shell have decided to phase out V-Power Racing from 21 July to mid August 2008, instead recommending V-Power[2]. The previously obtainable higher grade V-Power Racing which contained 5% ethanol to boost V-Power's octane rating to 100 RON has now been phased out by Shell due to a "changing market"..... In the United Kingdom and Denmark (where Super Unleaded must be a minimum of 97 RON), V-Power has a rating of 99 RON (whereas V-Powers' predecessor Shell Optimax was rated at 98 RON). There is one other 99 RON fuel available in the UK, namely Tesco MOMENTUM99. Seems u are correct..... |
| The Following User Says Thank You to FT-86GOD For This Useful Post: | EsoBOFH (06-29-2012) |
#23 |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
Costco, Arco, and Thrifty 91. There is a pump by my house with 100 but not sure how I feel about paying $9/gallon.
#24 |
Using Husky 94, 10% ethanol blend.
#25 |
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
#26 |
FRS Adept
Drives: Firestorm FRS
What happened to 87 ? Nobody ? Its not like you're harming the engine.
#27 |
Drives: truck and old car
California's highest octane is 91. Should we be using some kinda of octane booster? If so, what is recommended? thanks
