Old 03-03-2017, 06:41 PM   #15
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
Originally Posted by Cole View Post
I can guarantee my cat less header gave my car 100hp and ft-lbs over stock because I can feel it.
lol ok. i get it. you're one of those people. that's fine.
Atticus808 is offline   Reply With Quote
Old 03-03-2017, 06:59 PM   #16
Do I really need to explain the difference between OCD and OPD? Again?
Most people that claim they have "OCD" are not even close.
Obsessive–compulsive disorder (OCD) is a mental disorder where people feel the need to check things repeatedly, perform certain routines repeatedly (called "rituals"), or have certain thoughts repeatedly. People are unable to control either the thoughts or the activities for more than a short period of time. Common activities include hand washing, counting of things, and checking to see if a door is locked. Some may have difficulty throwing things out. These activities occur to such a degree that the person's daily life is negatively affected.[1] Often they take up more than an hour a day.[2] Most adults realize that the behaviors do not make sense.[1] The condition is associated with tics, anxiety disorder, and an increased risk of suicide
In the case of the car condition it would be OCD if you kept repainting it even though there was not a single chip or scratch.
OCPD is this:
Obsessive–compulsive personality disorder (OCPD) is a personality disorder characterized by a general pattern of concern with orderliness, perfectionism, excessive attention to details, mental and interpersonal control, and a need for control over one's environment, at the expense of flexibility, openness to experience, and efficiency. Workaholism and miserliness are also seen often in those with this personality disorder.[2] Rituals are performed to the point of excluding leisure activities and friendships. Persons affected with this disorder may find it hard to relax, always feeling that time is running out for their activities, and that more effort is needed to achieve their goals.
So in the same example you want the car to stay perfect even though it is not an even remotely realistic.
Not the same thing
Now we could go a little further into the autism spectrum where another large group of people that say they have OCD actually fall but we will keep that for Advanced Forum Psychological Condition Diagnosis For Dummies.
Cole (03-04-2017), humfrz (03-03-2017)
Old 03-03-2017, 07:01 PM   #17
Atticus808
Atticus808's Avatar
OCPD is this:
Not the same thing
becareful. Cole wants a doctors note.
Old 03-03-2017, 07:02 PM   #18
Originally Posted by Atticus808 View Post
i can guarantee that i have/had it.
some examples:
- i would use to collect tv guides and pile them up. once in awhile i would have to flip to a certain page, read a description, close the tv guide, put it back on top, sit back, and repeat that process 5 times.
- i would have to turn taps off and have the handle face a certain direction. if i screwed up, i'd have to leave the tap and redo it again 5 times or until it feels right.
- doing assignments or tests, if i write something and it doesn't feel right, i'd have to erase it and write it again 5 times.
- i fear contamination and germs. too many examples to list here.
everything in my life seemed to be run by numbers and i was seriously going crazy cause it was controlling me. eventually i just had to control it myself. i still have a bit of it but it's not as bad as it was 15 years ago.
Nope. Still not OCD. We will use you for a case study when we get into the levels/types of autism though.
Riftur (03-03-2017)
Old 03-03-2017, 07:03 PM   #19
Atticus808
Atticus808's Avatar
lol
how does it not make any sense. i pretty much matched that you posted
Old 03-03-2017, 07:13 PM   #20
lol
Pretty much but the wrong pattern. You said you would do it wrong and then have to keep doing it until you fixed it. OCD would just keep going back at random times and for no reason too make sure it was right. I was too lazy to type the symptoms out so just copied Wiki and the descriptions are very general. If you have about 8 weeks I can break down all the different disorders and we can narrow it down. What you described falls directly into the autism realm. You would be amazed at what you need to learn in my line of work.
Old 03-03-2017, 07:15 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
More people should consider OCD as something that legitimately hinders normal life and requires medication to manage.
Everybodies a little fucked up, kudos to anyone reading this who goes on to get help, I know I need it but it will always be 'tomorrow'.
ineedyourdiddly
Last edited by strat61caster; 03-03-2017 at 07:17 PM. Reason: I'm deeply unqualified to say anything else
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Atticus808 (03-03-2017), Cole (03-04-2017)
Old 03-03-2017, 07:16 PM   #22
Atticus808
Atticus808's Avatar
not do it wrong, but it didn't feel right. it would feel like something bad would happen unless it was done right.
there are a ton of different little things that i had to do, and i could only do it a certain number of times, and if it didn't feel right when it came to that number, i'd have to start over. and if i didn't do it, i would think something bad would happen.
i would seriously losing my mind over this stuff. it would actually control me. and the germs thing too.
Old 03-03-2017, 07:18 PM   #23
dutchman1
Drives: 2017 86 6-Speed
Back to the original question, I think it depends on why you bought your car. If you bought it to be a weekend cruiser/show car, then it makes sense to be irate over every physical detail. If you bought it to drive it on crappy back roads or plow through cones with, then who cares?
dutchman1 is offline   Reply With Quote
The Following User Says Thank You to dutchman1 For This Useful Post:
strat61caster (03-03-2017)
Old 03-03-2017, 07:21 PM   #24
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have COD and I end up doing the same thing over and over. I start the level and get shot.
I worry about my paint... And curbs. When my wife drives...
I LIKE TIRES!
Old 03-03-2017, 07:33 PM   #25
Magyarman
Magyarman's Avatar
Drives: 2016 FR-S series 2.0 , 2002avalon
Hard to see those scratches and dings at 40+mph.
When younger I would wash and wax so much my neighbor once commented that I was going to rub the paint right off of the car.
Today I wash and wax when I can and park at the far end of the lot or take my wife's 15yo Avalon.
Magyarman is offline   Reply With Quote
Old 03-03-2017, 07:50 PM   #26
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
I've gotten PDR done on my car 3x so far this month...Sigh.
KalbiCool88 is offline   Reply With Quote
Old 03-03-2017, 07:51 PM   #27
Gunman
Drives: 2019 Mazda Miata RF
I hate scratches, and dents. I can live with them if they are a result of driving, and enjoying the car, like scraping the front lip, I'm low, I expect that. When an idiot door dings it, that angers me.
The Following User Says Thank You to Gunman For This Useful Post:
KalbiCool88 (03-03-2017)
Old 03-03-2017, 07:53 PM   #28
KalbiCool88
This.
Sent from my A0001 using Tapatalk
Cheap way to fix Dents! Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 08-24-2014 03:41 AM
Scratches, Dents, Vandalism in GTA SPEEDGOD CANADA 16 12-04-2012 11:18 AM
Battle Scars - Dents/Scratches/Scrapes vent here! BigFatFlip BRZ First-Gen (2012+) — General Topics 5 06-22-2012 08:20 PM
Irrational Exuberance ?? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 20 11-29-2011 02:33 PM
