Northern California NorCal
Old 03-01-2017, 03:04 AM   #1
Corona1994
Drives: 2015 Scion FRS
Wheel offset advice??
What's the deepest offset I can run without having to go widebody, stretch my tires, or add excessive camber? I'm looking into buying 17x9.5 te37v ba. Want them as deep as possible while being flush with the fenders and having -2.0 camber at most.
Corona1994 is offline   Reply With Quote
Old 03-01-2017, 03:11 AM   #2
FirstWinter
Drives: Car
Ask in Wheels sub forum.
FirstWinter is offline   Reply With Quote
Old 03-01-2017, 03:19 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Here ya go
http://www.ft86club.com/forums/showthread.php?t=7535
Old 03-02-2017, 01:05 AM   #4
Kaotic Lazagna
Drives: GR Corolla
To give you a reference, my Weds are 17x9, ET35, lowered on Tein Flex Z (maxed low on the front, even-ish rear).
Alignment specs:
That is with 245/40/17 tires iirc.
For 9.5 wide wheels, offset would have to be +40 to be similar to my set up.
Old 03-02-2017, 01:14 AM   #5
MyRx
MyRx's Avatar
First, suggest wheels that someone makes for the FRS/BRZ.
Old 03-02-2017, 05:52 AM   #6
Corona1994
Yea, I didn't realize those don't come in our size.
Old 03-03-2017, 07:13 PM   #7
akahenry
akahenry's Avatar
Drives: '18 STi
Alignment specs:
Just out of curiosity, what other suspension supportings mods are you currently running with those Flex Zs? I might copy your set up huehuehue.
akahenry is offline   Reply With Quote
The Following User Says Thank You to akahenry For This Useful Post:
Kaotic Lazagna (03-04-2017)
Old 03-04-2017, 01:51 AM   #8
Kaotic Lazagna
Drives: GR Corolla
Just Whiteline rear LCA to correct camber as much as I can. I think I messed up the install on the passenger side since they couldn't even it out with the driver side.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
akahenry (03-04-2017)
Effect of wheel offset ddeflyer Tracking / Autocross / HPDE / Drifting 8 07-02-2014 07:29 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
need advice, 245/45/16 +35 offset... Walla Walla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-31-2014 01:46 PM
Stock Wheel offset smbrm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-15-2012 01:09 PM
Wheel offset on watanabes? Decameron Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2010 06:20 PM
