Old 02-24-2017, 10:20 PM   #71
Biggins
Drives: Yes
Originally Posted by simpleisbest View Post
Release Series 2.0 had same 7" wheels. 18" TRD Wheels were still listed as a dealer installed option with 7.5" for rear only, IIRC.
Are you sure? What about part #PTR20-18160-BK that seems to be the only wheel that comes on the 2.0?
Again, not doubting but only curious because I was thinking of getting a set of the Grey 17x7.5 TRD rims from the '17 86s for everyday driving.
Biggins is offline   Reply With Quote
Old 02-25-2017, 11:23 AM   #72
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
In Canada the RS2.0 came equipped with the 7.5J wheel, PTR20-18160-BK. It was not an extra option.
Cueman is offline   Reply With Quote
Old 02-26-2017, 04:58 PM   #73
dutchman1
Drives: 2017 86 6-Speed
So of the 17x7.5 TRD wheel is CS legal for the 86, you'd be able to run any 17x7.5 within offset parameters on any 86, being that they are a stand alone option?
dutchman1 is offline   Reply With Quote
Old 02-26-2017, 08:16 PM   #74
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
That's what it sounds like to me.
G_Ride is offline   Reply With Quote
Old 02-27-2017, 03:47 PM   #75
Cueman
Cueman's Avatar
Stand alone... but dealer installed.
The RS2.0 wheel is not available to those purchasing a standard model... even through the parts department, unless you can convince them you have an RS2.0 to put it on.
The TRD dealer option wheel is 18 7J +35 front and 18 7.5J +35 rear and has been available since 2014 at least. It hasn't been in play in previous years.
Did I miss something?
Old 02-27-2017, 06:15 PM   #76
TrqlessWonder
Drives: 2014 FR-S
Yep.. One detail I wanted to point out, lest some among us get overexcited and spend faster than we read.
The option is available on 86's.
The FR-S is not an 86
Neither is the BRZ
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 02-27-2017, 06:29 PM   #77
simpleisbest
Senior Citizen
Drives: Scion FR-S
I think you're right. The basic specs online do not match up with what actual RS2.0 owners are reporting about their wheels. With production limited to only 1000 units, expect it to be moved to CS once the SAC hears about it! LOL!
simpleisbest is offline   Reply With Quote
Old 03-06-2017, 11:48 AM   #78
SeanRTR
C-Street AutoX
SeanRTR's Avatar
So, Scoggs destroyed DS over the weekend....4 Cyl turbo Camaro was in a league of it's own. Any local have any info, other than 'Scoggs is an Alien"....?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 03-06-2017, 11:53 AM   #79
M0nk3y
Scroggs is an Alien.
Pretty much the end of discussion. He's a good driver. He still has room to improve with setup of the car, I talked with him on Sunday and he said he picked up time. Obviously he made the odd-ball pick for a car.
Low participation numbers in DS however, with a weird surface.
Old 03-06-2017, 12:38 PM   #80
G_Ride
G_Ride's Avatar
Not really. He's been pretty dominant so far at all of the local events he's been at. The closest anyone else got to him was his first event with the car.
Old 03-06-2017, 02:22 PM   #81
renfield90
The Stig's German cousin
Yeah, take SD results with a couple grains of salt. Garbage surface, fast course that is not necessarily autocross-ish, and the sloping site make for weird results that don't always transfer to other sites.
Old 03-06-2017, 02:23 PM   #82
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
He's got a great build thread over at the Camaro forums, good read for anybody who's looking into what it's like trying to build a competitive street class car and how some chassis get it better than others.
http://www.camaro6.com/forums/showthread.php?t=477232
The most mind blowing thing to me about that car is the weight, I wouldn't be surprised if after a day of autox you could put one on the scales and it'd be <3,200 lbs after it sheds factory wheels, exhaust, and junk in the trunk.
http://www.camaro6.com/forums/showpo...6&postcount=39
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Briankbot (03-07-2017), SeanRTR (03-06-2017)
Old 03-07-2017, 08:04 PM   #83
dvalue
Drives: 15 BRZ
Is pedal dance mode the only way to completely eliminate traction control?
I ran the car with traction control off and sport mode (hold for 3 seconds, etc) and still noticed that traction control would force its way back on.
dvalue is offline   Reply With Quote
Old 03-07-2017, 08:19 PM   #84
strat61caster
It sounds like you're not actually turning off traction control, hold the left button 'off' for ~5s, two yellow lights will illuminate and that's it, don't press anything else.
It sounds like you're pressing the 'off' button which is meant for snow/dirt only and turns off over 30 mph and/or pressing sport mode which will either cancel the 5s press (if you're doing that first) or it's sport mode + single press 'off' depending on your procedure.
Don't press 'sport mode' (unless you've got an automatic, in which case read your manual, it'll be different than what I wrote).
I personally prefer pedal dance, but there are many who don't, it's worth experimenting with, but I wouldn't do it during an event, I blew many runs trying to adapt during competition and didn't really understand it until I had a free test and tune day and an open figure 8 skidpad.
ineedyourdiddly
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 11:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 04:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 02:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 09:20 PM
