Old 02-24-2017, 04:47 PM   #15
put a box end wrench on the harmonic damper screw and see if you can turn the engine by hand.
Turn it slowly and only clockwise (from the perspective of looking at the front of the engine)
Old 02-24-2017, 10:02 PM   #16
He seems to have disappeared!
You know I never thought of that. May be pretty hard to turn with the plugs in it though since the compression is so high.
Ultramaroon (02-24-2017)
Old 02-24-2017, 10:05 PM   #17
I thought about going back to mention that. The compression is amazing but you can get through it just turning slowly and letting it bleed down.
Tcoat (02-24-2017)
Old 02-24-2017, 10:17 PM   #18
Would have been a handy trick with my old Ghia or Corvair. I never figured out an easy way to move those. About 35 years too late though.
Old 02-24-2017, 10:21 PM   #19
Never too late.
Old 02-24-2017, 10:41 PM   #20
Never too late.
HMMMM
Old 02-24-2017, 10:45 PM   #21
HMMMM
Do it! A colleague of mine is a Corvair guy. They're awesome.
shit, I fell for it. Tried to click on the pictures.
Tcoat (02-24-2017)
Old 02-26-2017, 02:45 PM   #22
Urmyson
I put a socket on the crank pulley and I was able to turn it counter clockwise about maybe 2 turns and then it got tight. then I can go clockwise about the same before it gets really tight. I didn't want to put a lot of force into it because I don't know exactly what I'm doing though.
If the motor was locked up would it turn at all?
Urmyson is offline   Reply With Quote
Old 02-26-2017, 02:56 PM   #23
Well, if you turned it counterclockwise, you just loosened the bolt/nut. Then you turned it clockwise and tightened it back up. So, no real turning of the crank.
humfrz is online now   Reply With Quote
Old 02-26-2017, 02:59 PM   #24
Urmyson
It turned the crank, all the pulleys and belt moved at least. But I put very little force into it either way. I can put a breaker bar on it, but I'm afraid I'll just break something else.
Old 02-26-2017, 03:07 PM   #25
As discussed above, I'm not so sure anyone except a big guy like @Ultramaroon could turn a crank using a box end wrench. Maybe yes, with a socket and breaker bar ....... if you could get one in there.
I just remember how difficult it was to crank the old engines, even with their low compression and using the leverage of a hand crank.
Old 02-26-2017, 03:12 PM   #26
*sigh* Never turn an engine backwards unless you know exactly how it affects it.
It's ok if it gets hard to turn in a springy way. That's normal. Just go slowly and let the cylinder pressure bleed down. You're looking to feel for a hard mechanical bind. If you feel that then you've already found what has broken. Not going to break it more. Not by hand.
If you can get 2 full rotations of the crankshaft then you have made it through a full rotation of the camshafts. You can consider it ok to turn over with the starter.
Old 02-26-2017, 03:16 PM   #27
Like mentioned above, crank it a ways clockwise till you feel resistance, then wait till the compression bleeds off, then turn it some more (still clockwise).
If you can get the crankshaft to make a full revolution, that would indicate that the engine is not completely locked up.
However, that doesn't mean you are completely out of the woods ...... you could still have a spun bearing that the starter motor can't overcome.
Where did @Ultramaroon and @Tcoat run off to ....... church ......??
Old 02-26-2017, 03:29 PM   #28
Hey, I'm here.
...doing laundry.
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 11:11 AM
