Old 02-24-2017, 12:08 PM   #1
curiosul
Drives: 1993.5 Infiniti G20
Few questions for 2017 stick shift owners
Actually thinking about getting one. I test drove one (see my impressions here) but I didn't have time to notice/check everything.
Questions:
1: What rpms do you get at 70 mph?
There's no youtube video of someone cruising (or even accelerating) in 6th gear. Maybe some one can post a youtube video of cruising, 1/3 throttle accelerating from 60 and WOT accelerating from 60 in 6th gear?
2: How accurate is the speedometer (compared to GPS)?
All the old cars I've had were doing around 67 when 70 was indicated.
The newest car I have (a 2016) is SPOT ON.
3: What kind of cruising MPGs do you get (flat road, no AC, 70mph, stock)?
4: How accurate is the indicated fuel consumption?
5: For "early adopters" (people who bought it in early fall) did you notice a big difference in fuel consumption between summer and winter blends of gas?
6: How do you get the high beams with the new headlights?
Is there a separate bulb (that I can't see in pictures) or is the whole assembly twisting up? Is it blinding for the incoming traffic or just a tad brighter than low beams?
Thank you!
curiosul is offline   Reply With Quote
Old 02-24-2017, 12:19 PM   #2
You do realize that most of these questions are unanswerable with any form of consistency right?
Fuel consumption numbers depend on how and where you drive and there is no way to compare from person to person.
Do not use GPS as the benchmark for speed. They are only accurate to a few hundred yards and the transmission lag (they are in space after all) means what you are seeing on the speedometer and what you are reading on the GPS are not actually happening at the same time. Always believe the speedo over a GPS no matter how accurate they claim it is. If you have the same number it is more due to coincidence than reality.
The high beams are a separate bulb just like the old ones. It will blind oncoming traffic exactly the same any other high beam on a car.
86geek (02-25-2017), Cole (02-24-2017), strat61caster (02-24-2017)
Old 02-24-2017, 12:45 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
1. about 3k rpm give or take
3. Should expect EPA numbers for freeway
4. It is optimistic by at least 10%
5. No, traffic conditions have a bigger impact.
ineedyourdiddly
Cole (02-24-2017)
Old 02-24-2017, 01:39 PM   #4
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Interesting- but your view differs from this:
http://gpssystems.net/accurate-gpsbased-speedometer/
Shinigami301 is offline   Reply With Quote
Old 02-24-2017, 01:46 PM   #5
Cole
Not a troll
Cole's Avatar
Very biased view. I have a GPS tracker in my work truck. Guess how it gets its speed readings? The OBD2 port.
You better have a damn good GPS to be able to calculate speed in real time with any accuracy. Ie, sub meter and sub second sampling. The whole 10m+ of accuracy really won't cut it here.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Old 02-24-2017, 02:16 PM   #6
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
In my '13 FRS at sea level it is about 3200 rpm, maybe 3100 but around there.
Your elevation will impact this.
DandoX is offline   Reply With Quote
Old 02-24-2017, 02:22 PM   #7
You really just used the GPS propaganda info to support GPS propaganda?
I am not even going to debate this and use whatever you wish.
Any difference is so small as to be meaning less anyway.
Old 02-24-2017, 02:26 PM   #8
Shinigami301
Certainly did not mean to irritate you with that, sorry if I did.
Old 02-24-2017, 02:50 PM   #9
LOL I think you read the wrong tone! Was supposed to be "banterish" not "angry sarcasmese". So hard to write how it is intended sometimes.
All is good and as long as the speed you are fighting isn't on a cop's radar gun then what does a couple of MPH matter to anybody anyway? Neither speedos nor GPS are exactly precision measuring instruments.
Ultramaroon (02-24-2017)
Old 02-24-2017, 02:51 PM   #10
strat61caster
What do you need to accomplish by having a more accurate speedometer?
I'm actually curious now...
ineedyourdiddly
Tcoat (02-24-2017)
Old 02-24-2017, 02:57 PM   #11
Was sort of my point all along. Most of the other original questions have little to no value as well.
Old 02-24-2017, 03:02 PM   #12
Shinigami301
Keyboard doesn't allow for much expression
Old 02-24-2017, 03:06 PM   #13
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
I always use the electronic speed warning signs around the city to gauge a vehicle's accuracy. As OP said, a lot of vehicles do understate their own speed. I'll go by an electronic sign indicating, for example 25 mph, at 32 mph, but the sign tells me I'm going 29 mph.
Borchert97 is offline   Reply With Quote
Old 02-24-2017, 03:14 PM   #14
DM7
Drives: '13 FR-S Argento
Tire wear will affect your speedometer reading as well. Going from a brand new tire with 9/32" tread depth to a bald one with 2/32" multiplied by 2 is 7/16" of change in diameter. Speedometer indicated speed will be higher than actual speed. Going from one tire make and model to another will change diameter as well even if they have the same size specifications.
Want accurate speed? Snapchat speed filter is the only way to go.
DM7 is offline   Reply With Quote
manual/stick shift dalli BRZ First-Gen (2012+) — General Topics 48 04-08-2016 01:01 AM
A quick video tutorial on how to drive a stick shift:) Andre Suwuh FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 03-17-2016 08:53 PM
Shift knob vs a shift stick? DVNARC Cosmetic Modification (Interior/Exterior/Lighting) 23 09-13-2015 08:33 AM
Driving stick shift (twins vs any other sticks) Drakelee117 BRZ First-Gen (2012+) — General Topics 60 05-28-2015 10:18 PM
Stick shift school in Houston? nitewolfgtr Southwest 6 09-07-2013 02:32 PM
