Drives: 1993.5 Infiniti G20
Few questions for 2017 stick shift owners
Actually thinking about getting one. I test drove one (see my impressions here) but I didn't have time to notice/check everything.
Questions: 1: What rpms do you get at 70 mph? There's no youtube video of someone cruising (or even accelerating) in 6th gear. Maybe some one can post a youtube video of cruising, 1/3 throttle accelerating from 60 and WOT accelerating from 60 in 6th gear? 2: How accurate is the speedometer (compared to GPS)? All the old cars I've had were doing around 67 when 70 was indicated. The newest car I have (a 2016) is SPOT ON. 3: What kind of cruising MPGs do you get (flat road, no AC, 70mph, stock)? 4: How accurate is the indicated fuel consumption? 5: For "early adopters" (people who bought it in early fall) did you notice a big difference in fuel consumption between summer and winter blends of gas? 6: How do you get the high beams with the new headlights? Is there a separate bulb (that I can't see in pictures) or is the whole assembly twisting up? Is it blinding for the incoming traffic or just a tad brighter than low beams? Thank you! |
#2 |
You do realize that most of these questions are unanswerable with any form of consistency right?
Fuel consumption numbers depend on how and where you drive and there is no way to compare from person to person. Do not use GPS as the benchmark for speed. They are only accurate to a few hundred yards and the transmission lag (they are in space after all) means what you are seeing on the speedometer and what you are reading on the GPS are not actually happening at the same time. Always believe the speedo over a GPS no matter how accurate they claim it is. If you have the same number it is more due to coincidence than reality. The high beams are a separate bulb just like the old ones. It will blind oncoming traffic exactly the same any other high beam on a car.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#3 |
Drives: '13 FRS - STX
1. about 3k rpm give or take
3. Should expect EPA numbers for freeway 4. It is optimistic by at least 10% 5. No, traffic conditions have a bigger impact. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Cole (02-24-2017) |
#4 | |
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
http://gpssystems.net/accurate-gpsbased-speedometer/ |
#5 | |
Not a troll
You better have a damn good GPS to be able to calculate speed in real time with any accuracy. Ie, sub meter and sub second sampling. The whole 10m+ of accuracy really won't cut it here. |
| The Following User Says Thank You to Cole For This Useful Post: | strat61caster (02-24-2017) |
#6 |
Senior gif poster
Drives: 2013 Asphalt FRS
In my '13 FRS at sea level it is about 3200 rpm, maybe 3100 but around there.
Your elevation will impact this. |
#7 | ||
I am not even going to debate this and use whatever you wish. Any difference is so small as to be meaning less anyway.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Cole (02-24-2017), strat61caster (02-24-2017) |
#8 |
Certainly did not mean to irritate you with that, sorry if I did.
#9 | |
All is good and as long as the speed you are fighting isn't on a cop's radar gun then what does a couple of MPH matter to anybody anyway? Neither speedos nor GPS are exactly precision measuring instruments.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (02-24-2017) |
#10 | |
I'm actually curious now... |
| The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (02-24-2017) |
#11 |
Was sort of my point all along. Most of the other original questions have little to no value as well.
#12 |
Keyboard doesn't allow for much expression
#13 | |
Drives: 2017 Toyota 86
#14 |
Drives: '13 FR-S Argento
Tire wear will affect your speedometer reading as well. Going from a brand new tire with 9/32" tread depth to a bald one with 2/32" multiplied by 2 is 7/16" of change in diameter. Speedometer indicated speed will be higher than actual speed. Going from one tire make and model to another will change diameter as well even if they have the same size specifications.
Want accurate speed? Snapchat speed filter is the only way to go.
| manual/stick shift | dalli | BRZ First-Gen (2012+) — General Topics | 48 | 04-08-2016 12:01 AM |
| A quick video tutorial on how to drive a stick shift:) | Andre Suwuh | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 03-17-2016 07:53 PM |
| Shift knob vs a shift stick? | DVNARC | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 09-13-2015 07:33 AM |
| Driving stick shift (twins vs any other sticks) | Drakelee117 | BRZ First-Gen (2012+) — General Topics | 60 | 05-28-2015 09:18 PM |
| Stick shift school in Houston? | nitewolfgtr | Southwest | 6 | 09-07-2013 01:32 PM |
