View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 01-30-2017, 07:42 PM   #239
calic
calic's Avatar
Drives: Subaru Brz
Originally Posted by Visitor.S View Post
im have same issue and looking for tsb, but my problem is my frs is already rebuild the engine and get the turbo kits, is that possible dealer still can do that? anyone knows dealer must be reflash the ecu? thanks
Just print out the tsb and go the dealership.
2015 WRB Limited Sti
Instagram: limitedbreeze
calic is offline   Reply With Quote
Old 01-30-2017, 07:48 PM   #240
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah that's fine you will just have to pay.
Old 01-31-2017, 07:55 AM   #241
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
As mentioned you can try and have to pay. I went that route and they still denied me because it was modified.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 01-31-2017, 09:05 PM   #242
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
I wonder if I can have this done to my car in Japan or is this a strictly US only TSB.
socal_48 is offline   Reply With Quote
Old 02-02-2017, 08:18 PM   #243
haxs30
Drives: Subaru brz
1 month since reflash and no issues and hard shifting yet.
haxs30 is offline   Reply With Quote
Old 02-20-2017, 04:10 PM   #244
FRS-RS1.0
Drives: 2015 FRS Release Series 1.0
I'm getting ready to have this done in Delaware... the TSB is a god send as it has been so annoying either resetting the car (off and back on) or constantly driving In manual mode...
I just have two annoying questions eating at me....
1) how come the TSB doesn't simply acknowledge the dynamic rev management issue (hard shifting)
2) shouldn't this be a recall??? Even if it was a silent recall I've been driving my RS 1.0 almost a year with this issue and thought there was no solution .... thanks Toyota
FRS-RS1.0 is offline   Reply With Quote
Old 02-20-2017, 04:18 PM   #245
Reamer
Drives: 2015 FRS
Have you tried putting it in "sport" before putting it in gear? As long as I put it in sport mode while I'm not moving then it doesn't seem to shift hard. My issue comes up when I'm driving in normal and switch to sport while moving.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 02-21-2017, 06:33 PM   #246
calic
calic's Avatar
Drives: Subaru Brz
I have the OFT flash. My car basically become unusable when i selected sport mode. It would start slamming into gear and was completely unable to drive normally.
Old 02-21-2017, 06:46 PM   #247
Reamer
Drives: 2015 FRS
This shouldn't matter what ECU flash you have. I ran OFT for awhile before I moved over to ecutek.
Old 02-21-2017, 08:43 PM   #248
calic
calic's Avatar
Drives: Subaru Brz
I can only speak from my experience before I had the TSB done.
It was bad in sport before i flashed. It got worse with OFT stage 1, since everything is set to be slightly more aggressive. With the flash the car and became somewhat un-driveable due to the shifting.
Old 02-22-2017, 02:01 AM   #249
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
I'm on stage 2, and haven't experienced any "slamming" of gears. Can you elaborate? Perhaps you need to have your trans relearn shift logic.
Sent from my P027 using Tapatalk
KalbiCool88 is offline   Reply With Quote
Old 02-24-2017, 06:05 AM   #250
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
Any non 15-16 AT frs/brz experiencing this issue? Was the dealer able to re flash your calibration successfully?
86two6 Thursday Meets in SoCal.
IG @86two6
Greddy86 is offline   Reply With Quote
Old 02-24-2017, 08:40 AM   #251
Cole
Not a troll
Cole's Avatar
Just be thankful you had no clue that this TSB existed, over fighting with Toyota Canada head office for 8 or 9 months to get them to perform the flash.
Cole is offline   Reply With Quote
Old 02-24-2017, 10:27 AM   #252
Told you to bring it to London. You would have been in and out of the dealer in 15 minutes with a shiny new flash on your TCU.
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 12:54 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 07:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 04:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
