#281 | |
That Guy
Drives: 2013 asphalt FRS MT
I hadn't realized there was an aero component to the center exit design. My apologies. How much of a difference are you seeing in cd between the center exit and twin exit? |
| The Following User Says Thank You to Calum For This Useful Post: | Silverfox (01-18-2017) |
#282 | |
Drives: 2012 FR-S
![]() I can't say exactly what kind of benefits the center has over the twin tip. We have spent a lot of time on the under-car aero and this design fit our needs (for the time being). With this kind of aero project we just listen to the pros, smile and nod. Disclaimer- To those considering this center exit for aero purposes, be aware that we have a custom designed aero package. A single component by itself may or may not make a huge difference. Each piece is a collective part of the entire car. |
#283 | |
Drives: 2015 FRS
#284 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I've gone a similar route with the turn as tails, exhaust hole covers but with with the Velox diffuser
#285 | |
Drives: 2015 FRS
Sent from my HTC 10 using Tapatalk |
| The Following User Says Thank You to Reamer For This Useful Post: | Jmonty (02-06-2017) |
#286 |
Drives: 2014 GT86
Best center exhaust looks are for DAMD rear bumper/center exhaust imho
#287 |
Drives: 2015 FRS
#288 |
Drives: 2014 GT86
Nope. I really like looks-wise damd/prova rear bumper/diffuser w. center exhaust. I guess, depending on exit tips type used maybe it can be used even with this Ace's exhaust. No clue though, how it will work together if one throws also some real diffuser into picture.
#289 | |
| The Following User Says Thank You to Jmonty For This Useful Post: | Reamer (02-07-2017) |
#290 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I like this exhaust. If I weren't going to a fully custom center exit design I came up with specifically for a highly efficient diffusor I'm also making, and needed to meet tight sound regulations, then it would be exactly what I'd want.
Personally I've never liked the rear 'diffusor' with twin exhaust cutouts on the FR-S... my temporary solution, spurred on by an aftermarket exhaust melting the passenger side cutout was this: ![]() GET RID OF THE STUPID FAKE FACTORY 'DIFFUSOR'. Cutting it out helped to bring more stability at high speeds too...was more unsettled than stock with the rear plastic in place without a stock type muffler. Eventually, once I get the custom exhaust mocked up then fabbed there will be a custom diffusor in store - like that of the TRD Griffon. Almost all of the premade diffusor solutions still use the stock 'diffusor'....meaning they won't be as efficient as a complete solution designed around a low profile center exit race exhaust that allows you to get rid of that factory nonsense. The Diode Dynamic Tail as Turn module works great for reverse, especially with the XP80 LED bulbs. Way better than stock, which is pretty useless as a reverse light other than as an indication to others that you are in reverse.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#291 |
The wait i hope is close to being over, late Christmas gift to myself
#292 |
Drives: 2018 BRZ tS
Pm sent
#293 |
Drives: 2012 FR-S
Production is up and running and kits are finally being shipped
You can check out details here: http://aceheader.com/index.php/produ...-system-detail |
| The Following 8 Users Say Thank You to AceHeader-MT For This Useful Post: | churchx (02-21-2017), gramicci101 (02-21-2017), MaximeT (02-21-2017), new2subaru (02-21-2017), Reamer (02-21-2017), Silverfox (02-21-2017), TkTk (02-21-2017), Ultramaroon (02-21-2017) |
#294 |
Drives: 2012 FR-S
We also have completed a "straight pipe" version with no muffler that will be track tested on the 22nd of Feb and another kit is on it's way to Qatar for more feedback
This version measured 103db at tailpipe at 6,000rpm using complete catless Ace system with just resonated mid-pipe No packing material, because Smooth is Fast This kit is not on website yet but cost will be $559 [ame="https://www.youtube.com/watch?v=hFHoxkhnsEM"]Ace Laguna Unlimited catback exhaust for BRZ GT86 - YouTube[/ame] |
| FNA rear fog light Kit 1 w/high power LED | HATED1 | Exterior Parts (Aero, Lighting, Etc.) | 5 | 02-09-2015 04:31 AM |
| HKS High Power Spec-L Ti-Tip | Tien | Engine, Exhaust, Transmission | 0 | 10-23-2013 11:54 PM |
| Mach V muffler delete prototype | Mach V Dan | Engine, Exhaust, Transmission | 118 | 02-01-2013 07:41 AM |
| 5W High Power CREE LED | Zoomryder | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-21-2012 06:30 PM |
