Old 02-20-2017, 03:35 PM   #1
illxkoncept
Drives: 2016 Scion FRS
OFT on AT
Has anyone ran into any problems with the openflash tablet on the automatic transmission? I heard about some people getting a transmission code.
illxkoncept is offline   Reply With Quote
Old 02-20-2017, 03:39 PM   #2
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
No issues with me.
DGM-BRZ is offline   Reply With Quote
Old 02-20-2017, 03:47 PM   #3
Cole
Not a troll
Cole's Avatar
P0700 is the code I've always gotten after flashing. Just erase the code and you're good to go.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
KalbiCool88 (02-20-2017)
Old 02-20-2017, 04:05 PM   #4
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
I have run the OFT on my AT '13 FRS for almost 2 years now without any problems. I have probably flashed 10+ times, and never had the transmission error code pop up.
-J.B.
golfyankee2121 is offline   Reply With Quote
Old 02-20-2017, 05:14 PM   #5
vietspride70
Drives: 2016 scion 86
I recently used it on16frs, works great, CEL comes on with p0700 only when I reflash... like other guy said, just clear it...problem solved.
vietspride70 is offline   Reply With Quote
Old 02-21-2017, 01:03 AM   #6
AREN
AREN's Avatar
Drives: Beige Corolla
I had the code as well, came on after installing my UEL headers and then flashing. The AT exhibited these slow shifts, and sloppy downshifts. It went away after driving about 20kms, and the AT was back to normal
AREN is offline   Reply With Quote
Old 02-21-2017, 01:45 AM   #7
phrosty
The code happens when the TCU loses connection to the ECU during flashing. It's normal and does not indicate any issues. Doesn't happen even time, either. I've flashed in the neighborhood of 50 tunes and have only seen it a few times.
Powerband changes can result in "abrupt" shifts where wheel torque no longer matches what the ECU expects it to be. Seems to only affect low RPM low acceleration upshifts, and nobody has solved this yet.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
AREN (02-21-2017)
Old 02-21-2017, 11:17 AM   #8
illxkoncept
After you cleared the code did you have any problems with the shifting?
Sent from my SM-G920R4 using Tapatalk
