Old 02-14-2017, 05:17 PM   #1
Bobster
Drives: GT86 GTS
2017 Track mode on older model
Hi Guys,
Tried looking for this online but no luck.
Can we get the 2017 traction control setting on to older models?
R
Bob
Bobster is offline   Reply With Quote
Old 02-14-2017, 05:31 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Isn't the track button in the 2017 a fancier way to say VSC Sport?
Old 02-14-2017, 06:11 PM   #3
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
The calibration is supposedly different; the new Track Mode allows more slip angle before the nannies intervene. Hopefully it's something as easy as changing some settings in Techstream.
Old 02-14-2017, 07:59 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
More likely is a different TCS module.
.: Stealth 86 :.
Kodename 47 DJ:
tCsonfrs (02-15-2017)
Old 02-15-2017, 06:54 AM   #5
steve99
Drives: FT86
your best option for a different tranction control system on older car wotld be to talk to moto east or deliceois tuning both have developed an alternate traction control strategy usinf ecutek racerom custom maps
trying to intergrate the 2017 traction vsc module into the older cars is unlikely to work easily.
see here
http://www.ft86club.com/forums/showthread.php?t=86034
Old 02-15-2017, 12:15 PM   #6
Chad_W
Drives: 2013 BRZ DGM
Search Pedal Dance to compare
Chad_W is offline   Reply With Quote
Old 02-15-2017, 12:36 PM   #7
Icecreamtruk
Drives: Track preped NA FRS
People talking about traction control here and I just here, wishing it didnt have any.
Icecreamtruk is offline   Reply With Quote
Old 02-15-2017, 01:07 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Pedal dance will be same on both year models, as on both it will switch nannies off with only basic ABS left. It's VSC vs Track mode, where differences will be, so why bring up pedal dance?
Icecreamtruk: one cannot guarantee skills all of car drivers will have. If you don't like and are skillful enough without, switch it off. Or buy some gadget to switch it off permanently on startup. Meanwhile i'll keep using VSC when driving on public roads and will give me some assurance if i'll know that most of others on road will too.
DAEMANO (02-15-2017)
Old 02-15-2017, 01:22 PM   #9
StraightOuttaCanadaEh
Wes
When I pushed the "S" button on my old Mini Cooper, it sharpened throttle response and added weight to the steering, both of which were lovely. I pretty much only drove with that mode on. Now my question is, does our car do anything else apart from relaxing the traction control a bit? Cause I do find the throttle response a little sluggish and find myself wishing there was an "S" button.
Old 02-15-2017, 01:58 PM   #10
stevesnj
stevesnj's Avatar
Just get the @86Nanny
http://www.beastronix.com/shop/86nanny-pedal-dance-abs/
My 2016 Build thread
Old 02-15-2017, 02:28 PM   #11
Icecreamtruk
No I totally understand what you mean. But what I mean is why cant I have a button to switch it off. Why must I do something like the pedal dance (which requires car warmed up, an annoyingly long sequence of inputs and needs to be redone every time). Why could they make the 5secs press like pedal dance, everything off except for ABS?
Old 02-15-2017, 02:55 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
You can have button to switch it off. It's even in post above yours. If your question is why Toyota/Subaru didn't implemented as button in stock car .. answer lies in country below yours . Big vendors don't need yet another class action suit for "making it too easy" from crashed & died hoons to fullfil wishes of small part of anti-nannies purists. As for myself .. it was hard to get PD right during first PD usage times on track to engage it .. but rather soon i learned sequence by heart & can quickly perform it if/when needed in track day, hence i won't shell any $$$ for buying that "button". There are many enough cars where there is no PD, nor even with TC off (which results in some funny stories from friends/colleges about eg. starting uphill on ice/snowed road). I'm happy with what we have. I'd wish for VSC to be tunable, but that's just wish, not must-have, as potential of it is Very Big (for example, with tunable one could learn control by gradually upping limits, letting it correct only very biggest mistakes that would result in spinout/crash anyway, one could actually drive faster, due electronics in potential being able to react much sooner then human (not that good for learning though), one could change the way it engages (eg. on new miata i found it way less unpleasant even if left on)).
Icecreamtruk (02-15-2017)
Old 02-15-2017, 03:06 PM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can get the car very out of shape with just the TCS fully off, why do you need the pedal dance? On track I can maybe understand but the main thing I get from the threads is that it stops the TCS turning back on if the car leaves the ground and disables EBD. Neither of these are necessary on the road so the button hold should be enough IMO.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-15-2017, 03:14 PM   #14
Icecreamtruk
As you said, this is mainly for the track. There is also winter driving. There is a noticeable difference between sliding around on ice with pedal dance, and sliding around on ice with button push only.
2017 brz exhaust vs older exhaust Joetheegyptian Engine, Exhaust, Transmission 19 04-07-2019 09:26 AM
'17 Toyota 86 Euro spec model - NA build/Street/Track Philliplo Member's Car Journals 20 11-21-2018 12:15 PM
Manual Trans gearing for 2017 model ? ToySub1946 Engine, Exhaust, Transmission 13 04-03-2017 04:41 PM
Older model parts fit 2016? JPRodney Scion FR-S / Toyota 86 GT86 General Forum 7 04-27-2016 02:59 PM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 04:07 PM
