Old 02-10-2017, 06:15 PM   #211
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Pure Automotive View Post
Electronics package is $5995. We have started adding all the swap parts to our website but are not finished yet. There is no correct answer for exactly how much the swap costs. I could list over 75 individual components that are required but instead I will give you the best everage price. If you bring the car to us and we do the whole swap it's going to be around $25k and that price is extremely variable based on a lot of options. I get about 5 emails a day about it and 1 in 20 of them makes it past the first email.
All I can say is, you can't truly appreciate this swap with our software until you drive the car. I took it out yesterday and we programmed all the MoTeC traction control, it's unbelievable. I will be making a video next week explaining all the levels of control. Just to give you an idea, it's so advanced that you can drop the throttle to the floor and never lift all the way through every gear and the car never breaks loose. It literally pedals the car for you. I've never felt safer driving a 500hp car on STOCK tires!
Does that include the engine and transmission?
Old 02-10-2017, 06:16 PM   #212
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Negative ghostrider
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
The Following User Says Thank You to itsjustdavep For This Useful Post:
Calum (02-10-2017)
Old 02-10-2017, 07:34 PM   #213
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I've seen the engines for $3000 but transmissions are all over the place, I wish I could buy them in bulk and be able to include them in the price but it's too variable to do so. You can save a few dollars here and there when piecing a kit together, example, this car has a $1700 precision turbo but it could be a $700 borg warner, it has a custom intake manifold that we sourced for $900 and modified, but it could be stock. You could get a $500 clutch instead of a $900 clutch. But the end result will vary and I don't know about you but if I'm going this far into modifiing the car, why do things twice?
Pure Automotive is offline   Reply With Quote
The Following 9 Users Say Thank You to Pure Automotive For This Useful Post:
Calum (02-10-2017), Dpk3 (02-12-2017), Draco_PR23 (02-10-2017), ILLSMOQ (02-10-2017), itsjustdavep (02-10-2017), juan86 (02-10-2017), R2RO (02-10-2017), Sportsguy83 (02-10-2017), turtlefeeder (07-25-2017)
Old 02-10-2017, 08:14 PM   #214
Calum
That Guy
Thanks for answering.
Just to be clear, I wasn't trying to nickle and dime the price. I just honestly had no idea. Also, that's about $40000 CAD. Which is WAY outside of my budget for car mods. I'm just here for the porn, wet dreams, and to learn.
Old 02-10-2017, 10:23 PM   #215
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by M1K3 View Post
Here you go embedded:
Awesome that you're doing an LS version too! I'd love this for my LS swap, and if it's a plug and play set up then I'm definitely in!
ILLSMOQ is offline   Reply With Quote
Old 02-11-2017, 11:09 AM   #216
Pure Automotive
Testing it in the next couple months, working on the harness now.
The Following User Says Thank You to Pure Automotive For This Useful Post:
ILLSMOQ (02-11-2017)
Old 02-11-2017, 11:40 AM   #217
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
$25k for a budget swap. With an open ended completion time. One year plus and counting.
OK
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
PandaSPUR (02-11-2017)
Old 02-11-2017, 11:52 AM   #218
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
OK
Well, the car is done as well as all the r&d and electrical work. So now that everything is finished it wouldn't take anywhere near that long to repeat. That price includes all labor, you can obviously do it yourself. It also includes a car that does every single thing a stock frs does, not a ghetto swap. Can you do it cheaper? Of course. Will it be crude? Probably. The amount of time we spent with the electronics package is well worth it. The capabilities of the ecu are endless and the car has every oem feature, some even more refined than oem.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 5 Users Say Thank You to spitfire481 For This Useful Post:
drew_kar (02-11-2017), ILLSMOQ (02-11-2017), itsjustdavep (02-11-2017), R2RO (02-11-2017), turtlefeeder (07-25-2017)
Old 02-11-2017, 03:58 PM   #219
Pure Automotive
Could literally knock this swap out in a month if all the parts were present. Oh and all the money from the customer would have to be present. Probably 2 weeks in reality. Who's next ?
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
Draco_PR23 (02-12-2017), Sportsguy83 (02-12-2017)
Old 02-11-2017, 04:03 PM   #220
itsjustdavep
How much extra fab work would be needed if this is being done in a garage? I remember reading that you had to modify the CX mounts?
Old 02-11-2017, 04:19 PM   #221
Pure Automotive
There's some drilling for that. The tunnel has to be clearanced, the trans mount should be welded for sturdiness, the shifter opening must be modified, the core support has to be modified, the firewall needs some adjustment,it's not just slip it in there affair.
Old 02-11-2017, 11:22 PM   #222
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
OK
I gotta agree with @Scrappydoo. I know swaps aren't for people strapped on cash, but when the topic says "Budget 2JZ Swap", I expect something lower than 25k. Isn't 25k for just kit + labor kinda normal pricing...?
The Following User Says Thank You to PandaSPUR For This Useful Post:
Scrappydoo (02-12-2017)
Old 02-12-2017, 02:12 AM   #223
MRS-Colin
Drives: 2001 Impreza 2.5 RS
except cruise control and emissions monitoring.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 02-12-2017, 02:38 AM   #224
Irace86
Drives: BRZ + Ducati M796
The 2jz can obviously handle tons of power. The r154 can hold over 500whp-700hp from what I read. Is the rear end a weak link at those power levels? How much more is the V160?
Just curious, is this a swap people do because they don't want an old Supra or can't find one or just really like the 86? Because this and a car is like $50k+. Seems like buying a Supra would be cheaper, or dropping a 2jz into something else would be cheaper. It is cool n all but just curious.
Irace86 is offline   Reply With Quote
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 09:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-21-2015 12:50 AM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 12:23 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 09:14 AM
