| Software Tuning Discuss all software tuning topics. |
#43 |
Drives: 2013 Scion Frs 6mt
Bro, why don't you try this,
After you get your fueling correct at WOT (MAF scale) take a base line pull with your original AVCS. Than make 3-4 intake cam maps from 1600-6000ish 1.0-1.4 loads set it to one value. For example 20, than 25, 30, and 35. Take virtual dyno results on each pulls than overlay them. You'll see where you gained power and lost. Than do this with the exhaust cam. Than timing (blanket effect) And probably back to fueling. (MAF scale) Obviously make sure with every pass oil and IAT temps are similar and the road is as smooth as can be. I know this is how people who have the ability to live tune tune for avcs at WOT. Also there's some good guides out there to help you create your own system of things. |
| The Following User Says Thank You to Nah For This Useful Post: | Tor (02-08-2017) |
#44 |
Drives: 86
scavenging refrash the gas in the cylinder . there are limit for it (peak power) set it over will lose more frash air and then lose tourqe . peak power hard to find .it takes many dyno runs and flashs .
| The Following User Says Thank You to aagun For This Useful Post: | Tor (02-08-2017) |
#45 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | freerunner (02-08-2017), Tor (02-08-2017) |
#46 | |
Drives: 86
inform me ^^ |
| The Following User Says Thank You to aagun For This Useful Post: | freerunner (02-08-2017) |
#47 | |
Drives: Toyota GT86
Thanks for the suggestion. That would take too many flashes to be feasible and I think VD is too unreliable to get reliable results. Add to that that I doubt I would be able to do this in one day and the uncertainties atmospheric conditions would cause.
Next thing is: Is it really worth the effort? The car runs great, has very very little torque dip, and it really wouldn't benefit the top end. I think I am done: - First, no one seems to be really sure if the dip is real and/or "supposed" to be there or not. - Clearly, it's related to the AVCS (as it disappeared when I accidentally drove with the AVCS off in error mode). So maybe it's "just there" when using those settings (and again the torque is good in that area). - Looking at it practically: Even if it dips for real in the cylinder, it's not significant (11.5). And it's not in an rpm range my car will see WOT very often with my usage. Driving on the street at 3500 rpm it will be in closed loop most of the time. - On track, it will almost never see WOT at 3500. Doing extensive further work on this seems like wasted energy. That doesn't mean it was a waste of time, on the contrary, I learned a lot of how things interact from messing with it. ![]() I do indeed intend to use the method to correct the lean spot between 4 and 5000 rpm (real or not, for knock prevention). Otherwise, my next focus will be to keep an eye on timing and adjust it, I am pretty sure it will be necessary when it gets warmer here. Quote:
| The Following User Says Thank You to Tor For This Useful Post: | Vin (02-08-2017) |
#48 |
Drives: UK GT86
The manual input of Intake/Exhaust overrides the load/RPM for the tables. Just delete the manual angles and it will work. Make sure the table values are showing 0s as ECUtek won't copy zero, it leaves the cell blank. Re-download, I made some minor improvements.
.: Stealth 86 :.
#49 | |
Drives: 86
#50 | |
Drives: Toyota GT86
Or would injector ratios play a part in the selection of firing angle? I noticed in the stock MY17 tune that GDI firing angle at e.g. 3600 rpm has been increased from 300 to 320 and 4000 rpm from 300 to 330. Except for the area where the ratios have been changed the rest of the table is virtually unchanged? Given that I have almost the same injector ratios as the MY17 (and OTS doesn't) I'm tempted to try to increase the 320 values to 330 from 4000 and load 0.8 and up and see what it does... My (OTS) injector values vs. stock v.s. MY17:
#51 |
Drives: 86
what the dyno say
#52 |
Drives: UK GT86
Think about it, if you increase the DI angle you are firing earlier in the cycle when there is more chance of overlap. It's hard to determine what will happen, but from what I've read you want later injection to cool the charge down at the right time of the cylinder fill. Honestly, I'd probably leave it. It won't gain you anything noticeable and you can't tell if it's good or bad either.
.: Stealth 86 :.
#53 | ||
Drives: Toyota GT86
A bit late to realize that, since I just did 2 flashes. First I did as said above and increased with +10 to match the MY17 tune. No difference (also smoothened the exhaust cam below 3600, and it felt like sh!t). So I flashed again with 340 like this (and normal cam): ![]() Then I went for another drive. First, a short log, upload and check that nothing was wrong. All looked okay and then I went and just enjoyed driving the car, what I actually didn't do for months. Result? No difference noticeable... A Haltech supporter wrote the following in their forum: Quote:
#54 |
Drives: GT86
#55 |
Drives: 86
#56 |
Drives: GT86
It's not ready yet. I'm currently redoing everything after discovering 86inches/kodename47's new maf scaling spreadsheet. The math really exposes all the dirty deeds.
Here's a log from the wip though: Click |
| MAF Scaling - Open/Closed Loop Fueling info | steve99 | Software Tuning | 653 | 07-10-2024 04:25 AM |
| Stuck in Open Loop? | Wepeel | Software Tuning | 34 | 05-19-2017 06:30 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Fuelling Issues (ECUtek ROM) | Kodename47 | Software Tuning | 4 | 03-17-2014 04:13 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
