| Engine Swaps Discussion of engine swaps. |
V8 Swap wiring questions
Where are you guys putting the factory ECU? Where are you putting the GM ECU? Which O2 sensors are you using and just the 2 main O2? Also what are you doing with the 12" length of the harness that is attached at the engine bay to make it clean?
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
This is going to be interesting. So how are you fitting both engines in?? I see you are running 2 ECU's one for each motor?? |
#3 |
Drives: 2001 Impreza 2.5 RS
The factory ECU is actually inside the car, not the module that is in the engine bay. That is the injector driver.
Colin Beck
| The Following 4 Users Say Thank You to MRS-Colin For This Useful Post: |
#4 |
Oh thank you for that. That makes things much easier. So I need to create a patch harness from the Factory ECU to the GM one. are people putting that inside? I saw the Vorshlag kit is putting it where the factory battery goes but I'm not trying to move that. Also do you know if the factory ECU plugs are available so I can pin my own harness? I'll dig around a bit to see if there is anything but I wanted to see if anyone found them already.
#5 |
Drives: 2013 Scion FR-S Series 10
You need the FRS ECU in order to run all the amenities. Power Steering, Tach, Speedometer, Fuel level, ABS, AC etc. The new box from MRS lets the ECUs basically talk to each other making alot of that stuff work. So yes, you do need the FRS ECU as well as the GM ECU.
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
#6 |
Drives: 86
frs can work fine with other engines. all what we need are frs crank single and and temp senser for rpm and heat gauges . but cel will glow up . rpm works and temp works also fans
#7 | ||
Reason for leaving the factory ECU is that we base all of the message timings off of it and it also provides signals for brake input and cruise control buttons. If you are manually wiring up a crank angle sensor and dual coolant temp sensors for the CAN stuff to work, yes.
Colin Beck
| The Following User Says Thank You to MRS-Colin For This Useful Post: | CxG (04-04-2017) |
#8 |
My plan is to run both ECU's have the GM computer run the engine but I'm unsure of what I need to hook up between the 2 ecu's if anything. I need to find some factory ECU plugs so that I can make it plug and play and have the ability to utilize the big square plug that's in the engine bay.
#9 |
AC1 ECM
1 Knock 1 B28 2 VV1+ B26 3(shielded C) Crank position + B16 4 Coolant Temp THW D30 5 Camshaft positon VC B34 6 VSV/MAF E2 D29 7 MAF E2G A29 8 Cam timing Oil 1E D7 9 Ignition 1 D21 10 ignition 4 D8 11 CPC solenoid D11 12 Knock 2 B17 13 VV2+ B15 14(Shielded C) Crank Position - B27 15 EV1+ B14 16 Fuel Pressure PR B9 17 MAF THA A12 18 MAF VG A22 19 OX1B O2 Sensor B1S2 B21 20 Ignition 2 D10 21 E2 O2 Sensor B1S2 22 Oil Pressure 23 VSV Pim B20 24(shielded B) Throttle Body VTA2 D28 25(shielded B) Throttle Body VTA1 D18 26 cam position bank 2 Exhaust (EV2+) B25 27 Oil temp OT D20 28 VSV VC D19 29 A1A+ O2 Sensor B1S1 B19 30 A1A- O2 Sensor B1S1 B18 31 ignition 3 D31 32 Cam timing Oil 1i D17 33 Cam timing Oil 2i D16 34 Ground B2 35 Ground B1 36 Ground D4 37 Ground B3 38(shielded A) Throttle Body M+ D2 39(shielded A) Throttle Body M- D1 40 Ground D3 41 B+ O2 Sensor B1S1 42 Smart Entry 43 Smart Entry 44 Cam timing Oil 2E D5 45 B+ O2 Sensor B1S2 46 HA1A O2 Sensor B1S1 B5 47 HT1B O2 Sensor B1S2 D6 48 EFI Main Relay B+ 49 ignition B+ 50 AC Clutch 51 injector port 4 D13 52 injector port 3 D32 53 injector port 2 D22 54 injector port 1 D12 |
#10 |
Does this list look correct for the AC1 connector in the engine bay? I had to cross reference last night using the service manual and wanted to make sure I have it all correct before I start making a harness. The left set of numbers is the pins on AC1 and the right letter/numbers is for the ECM.
#11 |
Guest
Posts: n/a
Weapons Grade sells their standalone wiring harness with integration ala carte if interested.
#12 | |
Not Bаnned Anymore
Oh I didn't know you could hook them together like that. Good to know, sorry haha!! |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | chaoscentral (02-08-2017) |
#13 | |
Drives: Supercharged GT86
#14 |
Drives: Red BRZ
| 1JZGTE SWAP [QUESTIONS] | Edsc | Engine Swaps | 3 | 11-20-2016 09:33 PM |
| Questions on new swap idea, need input! | Tectoniic | Engine Swaps | 11 | 10-28-2016 06:20 PM |
| Questions Related to Hard-wiring Dashcam | carma143 | Electronics | Audio | NAV | Infotainment | 2 | 09-09-2015 06:26 AM |
| Stock amp/wiring questions | Matey | Electronics | Audio | NAV | Infotainment | 5 | 08-22-2015 09:28 AM |
| Engine swap questions | kaluce | Other Vehicles & General Automotive Discussions | 9 | 09-20-2014 06:48 PM |
