Old 12-22-2016, 02:25 PM   #43
churchx
churchx's Avatar
Drives: 2014 GT86
Given cheap price of these .. isn't it simpler to just get another one new wheel instead of broken one instead of fixing them?
Old 12-22-2016, 02:29 PM   #44
ML
ML's Avatar
Drives: 13 White MT FR-S
Mine have been powder coated. I'm going to 18s in 2 weeks anyways. But yes It would be easier and safer normally.
Old 12-22-2016, 04:14 PM   #45
Pat
Pat's Avatar
Drives: 2023 BRZ
Yikes, good to know. I clean and inspect mine after every track weekend.
Old 12-23-2016, 11:22 PM   #46
Bimble Bamble
Drives: 10 Series
Originally Posted by novice View Post
I just installed some of these last night. I wasn't going to buy wheels and tires for a while since my 2.0 has low mileage but couldn't resist $169 per wheel.
TRD Springs, K4R 17x8 +36 225/45/17 MPSS Almost perfect. Front could use some camber adjustment to match the back perfectly but could do without it.
Looks great, Thanks for sharing! I've been looking at these wheels too and have trd springs as well!
Bimble Bamble is offline   Reply With Quote
Old 12-24-2016, 12:06 AM   #47
novice
novice's Avatar
Drives: Fr-S 2.0 Release
Originally Posted by ML View Post
FYI be really careful with light wheels like these if you daily them. My set has seen a lot of use and been welded once before, now needs to be welded again.
what causes this, pot holes etc?
novice is offline   Reply With Quote
Old 12-26-2016, 10:15 AM   #48
ML
ML's Avatar
anything not smooth that comes in contact with the wheel, such as pot holes, or small animals. Having under inflated tires will compound this issue.
Old 12-26-2016, 01:05 PM   #49
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Powder coating process can also weaken the alloy and contribute to it being more easily damaged.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 12-26-2016, 01:19 PM   #50
mbrs1.0
Drives: 2015 FRS RS 1.0
I feel that these wheels are meant to be replaceable, being affordable.
Sent from my SM-G928V using Tapatalk
mbrs1.0 is offline   Reply With Quote
Old 12-27-2016, 11:31 AM   #51
ML
ML's Avatar
true, but since these were cracked once before the powder coating I would still take caution.
Old 02-07-2017, 02:42 PM   #52
JoeC
Drives: Subaru BRZ Limited
I just got a set of these in 17x8 +36 from TireRack for $169 each. Seemed like a heck of a deal. Thanks @Pat for the recommendation!
JoeC is offline   Reply With Quote
Old 02-07-2017, 02:52 PM   #53
mbrs1.0
Post some pics. What tires? I will be getting these soon as well.
Old 02-07-2017, 03:13 PM   #54
JoeC
There are a bunch of pics in this thread. I just ordered them this morning and probably won't even mount them until our first track event at the end of March.
Old 03-28-2017, 10:52 PM   #55
TheLaughingMan
TheLaughingMan's Avatar
So I've had these wheels for quite some time now and love them. However, I now make more than double the HP I did when I first installed them.
I originally had MPSSes 225/45/17 but was looking to move up in tire size. What do you guys think would be the largest these 8" rims could handle? I was originally considering 255s but think I may be dropping that down to 245 now after some reading around.
Thoughts?
TheLaughingMan is offline   Reply With Quote
Old 03-28-2017, 11:01 PM   #56
mbrs1.0
Thoughts?
245 should work well. They are no longer available on tirerack btw.
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 07:37 PM
Wheel Directory: XXR 535 17x8.25 +35 PineappleFriedRice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 10-24-2014 09:27 PM
Wheel Directory: OEM VW Corrado (BBS RSM) 17x8.0 +35 koevasi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-02-2014 02:08 AM
Wheel Directory: Advan TC II 17x8.5 +45 driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-08-2013 03:45 PM
Wheel Directory: XXR 522 17x8.0 +48 STEVEOSTI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-13-2012 01:39 AM
