Old 02-03-2017, 10:43 AM   #1
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Raceseng camber plates/KONI
I'm having fitment issues with my Raceseng camber plates mounting on the KONI Yellows with lowering springs. Is anyone running a Raceseng plates with KONIs or Bilsteins with lowering springs? The top nut that mounts the top hat to the strut seems to be tightened all the way and there is still quite a bit of play with the spring. I tried burping the nut with an impact and even tried holding the piston with vice grips (with a rag of course) and the nut will not tighten anymore. I emailed Raceseng and they said they have no experience with working on KONIs which is weird since they sell a product that's supposed to work with KONIs. Is the spring supposed to sit loosely in the strut?
Devil 86 is offline   Reply With Quote
Old 02-03-2017, 11:10 AM   #2
Cole
Not a troll
Cole's Avatar
Did you get the ones with the 15mm spring perch bushing and the 90mm spring perch? That's what their website shows for the Koni's
Cole is offline   Reply With Quote
Old 02-03-2017, 11:24 AM   #3
Devil 86
Devil 86's Avatar
Yes I got the option that's supposed to work with the KONIs straight from their website.
Old 02-03-2017, 01:12 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What kind of lowering spring?
Without seeing it, so take this all with a massive grain of salt: I presume your lowering springs are shorter than the stock springs, combine that with the raceseng plates which are lower profile than the OE top hats and now you have a gap between the spring and the top hat when you are in the air, the Koni's don't have anything to do with it, you'd have the same issue if you had the stock damper + lowering spring + raceseng camber plates.
Easiest solution would be to have a 'taller' spring perch made to match how 'tall' the OE top hat is. Or you could just set it down on the ground and go drive it, odds are nothing bad will happen if this is truly what's going on.
The joys of combining modifications.
ineedyourdiddly
Cole (02-03-2017)
Old 02-03-2017, 01:27 PM   #5
Devil 86
Devil 86's Avatar
This is EXACTLY what's happening. Lol. So I just found out that this is normal and I should be fine.
The Following 2 Users Say Thank You to Devil 86 For This Useful Post:
Cole (02-03-2017), finch1750 (02-03-2017)
Old 02-03-2017, 01:40 PM   #6
Cole
Not a troll
Cole's Avatar
Ha! Classic, that's what you get for mixing and matching. Glad to hear it worked out for you.
Old 02-03-2017, 01:56 PM   #7
strat61caster
I'm still curious what spring you are running, I'm contemplating a setup very much like yours at some point down the road.
Thanks.
ineedyourdiddly
Old 02-03-2017, 02:04 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Damn. That would worry the shit outta me without knowing haha. Glad you got it straightened out
Old 02-03-2017, 02:45 PM   #9
Devil 86
Devil 86's Avatar
RCE Tarmac springs
Velox vs Raceseng Camber Plates ChrisSC300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 09-21-2021 03:00 PM
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 11:28 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 06:34 PM
F/S: Raceseng Front Camber Plates ExxelDistributions Brakes, Suspension, Chassis 6 10-25-2014 04:02 PM
