#15 | |
If that didn't work I just ran a #10 sheet metal screw between the post and the clamp. (Don't do this)
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (01-25-2017) |
#16 | |
)Iffen you break the post lose from the battery case, while pounding on it, just smear a large glob of roofing tar over the break. CAUTION: If the battery acid squirts out during the process, don't scratch your crotch with your hands after you clean it up ...... ![]() @Tcoat ....... do you have any distant relatives that came from West Virginia or Kentucky .... ?? humfrz |
#17 |
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Could there be something wrong (loose connection, bad ground) between the starter push button and the wiring to the battery? Could the push button itself be bad?
#18 | |
Drives: '13 SSM BRZ Limited 6MT
Only happens rarely. |
#19 |
Have you tried this sequence - hold the button in and then push the clutch pedal in?
#20 | |
There is no mystery here.
| The Following User Says Thank You to Tcoat For This Useful Post: | winstonscifi (01-26-2017) |
#21 |
Persona Non Grata
Drives: '15 BRZ (WRB)
The explanation for the rapid click/weak battery phenomenon is pretty simple. When you turn the key to the start position the battery has enough power to energize the solenoid. Once the contacts in the solenoid close (click #1), the increased demand by the starter causes enough of a voltage drop that the battery can no longer offer enough power to keep the solenoid energized so the solenoid opens/releases (click #2). Once it releases, the battery is no longer being hammered by the starter and once again has enough power to energize the solenoid (click #3).
Rinse/repeat 20 times per second or so. As most have noted, it's a pretty safe bet a new battery will fix it. I would suggest trying to figure out why this one went dead. edit: The same logic works for the push button starters. The difference is it's the ECU activating the solenoid.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | tracerit (01-26-2017) |
#22 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#23 |
| Watch "Turbo frs first start up." on YouTube | SoCal80six | Forced Induction | 0 | 10-08-2015 02:15 AM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "Invidia High Performance" Displays on Touchscreen (head unit, GPS) During Start up | carloverx | Software Tuning | 2 | 11-23-2013 02:08 PM |
| Engine doesn't start right away | Cajun | Issues | Warranty | Recalls / TSB | 1 | 02-04-2013 03:09 PM |
| Note: "Auto" does not start BRZ | Dorb | BRZ First-Gen (2012+) — General Topics | 14 | 12-02-2012 12:04 AM |
