Old 01-26-2017, 04:26 AM   #1
BRZ-086
Master Cheif
BRZ-086's Avatar
Drives: Subaru BRZ 2016 Metallic Ice Silver
BRZ intergrated mirror turn signals
Full replacement Led mirror turn signals convex and defroster polarized blue lens pictures of install.
The company that produces them Thespeedline cost about $105 shipped
Install requires removing the door panel, mirrors left and right side, and taping into the factory turn signal wires located beneath the drivers fuse box.
Install time 3hrs if you haven't removed a door panel, center shifter panel before.
Tools needed, wire strippers, Philips #2, socket and ratchet, nitrile gloves for rubber butyl removal, small angled wire cutter, heat shrink, crimpers, t-taps RED, zip ties, test light/multi meter, electrical wire to extended passenger wire to fuse box.
Quality of mirrors feel of good quality and workmanship I recommend these. REXS
EED mirrors come from the same factory as these without the intergrated turn signals FYI.
"Tip when routing wires from the mirror housing run the wires thru the top of the weather strip lining don't go thru the gasket between the door and body because it is one long piece starting from the top and runs down the gasket into the vehicle" if you ever seen the diode dynamics video on installing their full replacement mirror assembly they pull off the gasket and run the wire on top of the gasket and not inside, that can cause a short and wires are visible and can lead to chafing of the wires.
BRZ-086 is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZ-086 For This Useful Post:
carsebuco (10-23-2017), Tcoat (01-26-2017), toijin (01-28-2017)
Old 01-26-2017, 08:09 AM   #2
Certainly increases visibility a bit.
Old 01-26-2017, 09:34 AM   #3
halleffect
halleffect's Avatar
Drives: 2016 Subaru BRZ Series.Hyperblue
Any pics of what the mirror looks like with the LEDs off?
halleffect is offline   Reply With Quote
Old 01-26-2017, 10:24 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Any idea the cost?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-26-2017, 10:56 AM   #5
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Kind of stupid imo. If I wanted that I would've bought a mercedes
Silver Cervy is offline   Reply With Quote
Old 01-26-2017, 11:15 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
I'm surprised side blinkers weren't a standard option, almost all the cheap econobox cars have them already. They actually are very useful when changing lanes.
Current DD: M235i
The Following User Says Thank You to 8RZ For This Useful Post:
Premium 615 (11-01-2017)
Old 01-26-2017, 01:45 PM   #7
KnightRyderx2
Drives: 2014 FR-S
Convex too?
KnightRyderx2 is offline   Reply With Quote
Old 01-27-2017, 02:19 AM   #8
BRZ-086
Master Cheif
BRZ-086's Avatar
Originally Posted by 8RZ View Post
Any idea the cost?
$104.20 shipped.
It is also convex, eliminates blind spots
Below turn signals off shown.
Old 01-27-2017, 08:05 AM   #9
BRZ-086
Master Cheif
BRZ-086's Avatar
Yes it acquires attention on the road!
Old 01-27-2017, 09:23 AM   #10
BRZ-086
Master Cheif
BRZ-086's Avatar
Just posted some, your welcome
Secrecy is security and security is victory.
Old 01-28-2017, 12:57 PM   #11
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Looks nice
Jmonty is offline   Reply With Quote
Old 01-28-2017, 02:20 PM   #12
mitch t
mitch t's Avatar
Drives: stx class lava frs
Looks nice.
mitch t is offline   Reply With Quote
Old 10-23-2017, 01:57 AM   #13
Azyael
Drives: Toyota 86
I just bought my 86 and I got these mirrors.
I'm thinking about bringing it in for them to fix some annoying rattling on both doors. Think I can convince them to install these for me when they have the door panels off anyways?
Azyael is offline   Reply With Quote
Old 10-23-2017, 01:05 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
sure, if you pay them.
Chimera (10-23-2017)
brz, intergrated, led, mirrors, turn signals
How to take apart frs Turn Signals? Hentai Cosmetic Modification (Interior/Exterior/Lighting) 6 10-12-2016 01:49 PM
Turn signals don't always automatically turn off one2onejackpot Issues | Warranty | Recalls / TSB 6 04-18-2016 08:35 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 11:40 PM
LED turn signals on side mirror Shindig Cosmetic Modification (Interior/Exterior/Lighting) 1 11-22-2013 01:40 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-12-2012 12:23 AM
