Old 01-25-2017, 09:36 PM   #15
Good hint.
Then you might have to take the bolt out and cut a slice off of the clamp.
If you grind them down too much, Bubba says just to beat on the top of the post and clamp with a ball peen hammer ........
Been there. Done that.
If that didn't work I just ran a #10 sheet metal screw between the post and the clamp. (Don't do this)
humfrz (01-25-2017)
Old 01-25-2017, 10:09 PM   #16
OR ....... (now, what could go wrong down here: ......)
Iffen you break the post lose from the battery case, while pounding on it, just smear a large glob of roofing tar over the break.
CAUTION: If the battery acid squirts out during the process, don't scratch your crotch with your hands after you clean it up ......
@Tcoat ....... do you have any distant relatives that came from West Virginia or Kentucky .... ??
Old 01-25-2017, 10:31 PM   #17
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Could there be something wrong (loose connection, bad ground) between the starter push button and the wiring to the battery? Could the push button itself be bad?
winstonscifi is offline   Reply With Quote
Old 01-25-2017, 11:14 PM   #18
tracerit
Drives: '13 SSM BRZ Limited 6MT
As far as I know it's only happened in the cold. My original post was Sept 2016, don't remember how cold it was then. But it's cold now for sure. By cold j mean CA cold, 40F.
Only happens rarely.
tracerit is offline   Reply With Quote
Old 01-25-2017, 11:23 PM   #19
winstonscifi
Have you tried this sequence - hold the button in and then push the clutch pedal in?
Old 01-26-2017, 09:15 AM   #20
The push button just send a signal it doesn't carry any current.
There is no mystery here.
winstonscifi (01-26-2017)
Old 01-26-2017, 12:27 PM   #21
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The explanation for the rapid click/weak battery phenomenon is pretty simple. When you turn the key to the start position the battery has enough power to energize the solenoid. Once the contacts in the solenoid close (click #1), the increased demand by the starter causes enough of a voltage drop that the battery can no longer offer enough power to keep the solenoid energized so the solenoid opens/releases (click #2). Once it releases, the battery is no longer being hammered by the starter and once again has enough power to energize the solenoid (click #3).
Rinse/repeat 20 times per second or so. As most have noted, it's a pretty safe bet a new battery will fix it. I would suggest trying to figure out why this one went dead.
edit: The same logic works for the push button starters. The difference is it's the ECU activating the solenoid.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
tracerit (01-26-2017)
Old 01-27-2017, 01:37 PM   #22
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Exactly!
billwot is offline   Reply With Quote
Old 01-27-2017, 03:56 PM   #23
Originally Posted by billwot View Post
Exactly!
You're late to the party, there, billwot ...... does the battery on your electric scooter need to be recharged ......
Watch "Turbo frs first start up." on YouTube SoCal80six Forced Induction 0 10-08-2015 02:15 AM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"Invidia High Performance" Displays on Touchscreen (head unit, GPS) During Start up carloverx Software Tuning 2 11-23-2013 02:08 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 03:09 PM
Note: "Auto" does not start BRZ Dorb BRZ First-Gen (2012+) — General Topics 14 12-02-2012 12:04 AM
