Old 01-25-2017, 09:05 PM   #43
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What you're showing isn't ideal, but is unlikely to cause any issues.
Your camber is not adjusted evenly, the multiple screw holes are there to facilitate alignments. You can make it 'look' even, but it's a gamble if it actually is unless you or someone else measures it. A good alignment shop will adjust it for you in an ideal way, but that of course costs money.
Not a bad idea to go back and button it up, but you will still need to tighten up every nut and bolt you can find to try and solve the noise if you can. It may be a spring binding on the perch, only solution would be a bearing between the spring and a perch.
Stiffer swaybar would only add another noise source as another aftermarket component that doesn't live up to OE standards. It certainly won't make anything quieter unless it corrects something like a swaybar rubbing.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Kendallkab (01-25-2017), Yoshoobaroo (01-27-2017)
Old 01-25-2017, 09:07 PM   #44
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
And also note OP that camber plates replace the oem rubber top hats so NVH will increase no matter what so it may just be something you live with from now on
Old 01-25-2017, 09:14 PM   #45
Kendallkab
Drives: Black MT LMT BRZ
Oh. Thats just the camber adjustment. Looks ok from that angle otherwise. Though get an alignment if you havent already cuz that seems a little funky lol
Double check the spring preload and possibly try unhooking an endlink to see if the noise goes away. I would also rear the threads with other people who have the same coils to see if they have the same noise and what the fixes were.
I'm gonna mess with the preload next and get an alignment then.. that gap scared me.
Kendallkab is offline   Reply With Quote
Old 01-25-2017, 09:16 PM   #46
finch1750
finch1750's Avatar
The way you described it scared us haha. Glad it wasnt as bad as we thought. Did the coils come with the preload adjusted already?
Old 01-25-2017, 09:18 PM   #47
Kendallkab
Ok.. I'm not used to noises like that lol. This is my first real life mod. I'm going to mess with preload a little bit not too much based off what someone else said.. make sure everything is tight again and then get an alignment.. the noise isn't even that loud it's just when I turn music down I hear it and I automatically think something is wrong..
No everything was loose when I got them
Old 01-25-2017, 09:25 PM   #48
ryoma
ryoma's Avatar
assuming that you can set the preload and height independently, tighten up the preload collar enough so that the spring cannot move but not too much that it compresses the spring. if you want to control the height, use the other collar.
The Following User Says Thank You to ryoma For This Useful Post:
Kendallkab (01-26-2017)
Old 01-26-2017, 11:56 AM   #49
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
You can see the ground on one picture
Just like finch1750 said it's camber adjustment. Right and Left should be same setup. Most people dont touch camber setup at home because have to get alignment so go to alignment or tuner shop and tell them what you want for camber. i would go with -1.5 or -1.6 at front and -1.0 on rear
right height is similar or same on right and left?
I cant believe your friend installed camber that way lol
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 01-26-2017, 01:05 PM   #50
8R6
8R6's Avatar
Drives: FRS
kinda hard to tell without a wider shot for reference, but i think your driver-side tophat is backwards.
[edit] looking at your pictures closer, im almost 100% positive your tophats on BOTH sides are going the wrong way.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Old 01-26-2017, 02:39 PM   #51
zc06_kisstherain
Drives: SWP BRZ
it may be...L should be installed on driver side and R should be installed on passenger side.
also "L" & "R" should be readable from you standing in front of wheel.
Old 01-26-2017, 02:48 PM   #52
8R6
8R6's Avatar
Drives: FRS
i think he does have the L/R in the correct sides like you described, but the tophats and camber plates look like theyre mounted in the wrong direction
Old 01-26-2017, 03:24 PM   #53
zc06_kisstherain
Drives: SWP BRZ
that's what i am thinking too.
it's readable from Engine to wheel point.
still OP needs to take it off and re install properly
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
8R6 (01-26-2017), Kendallkab (01-26-2017)
Old 01-26-2017, 04:20 PM   #54
KnightRyderx2
Drives: 2014 FR-S
These guys are correct, those top hats are positioned the wrong way. The "L" and "R" is supposed to be on the fender side. So if you look at the first pic, the "L" needs to be on the bottom right side. This makes the camber adjustment a side to side adjustment. As you have it now your camber would adjust corner to corner and that is not cool.
As for preload adjustment, this is a pretty good write up on how to do it. Its Megan coilovers but they are set the same way. Also you can do this while coilover is on the car.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
zc06_kisstherain (01-26-2017)
Old 01-26-2017, 04:52 PM   #55
zc06_kisstherain
Drives: SWP BRZ
if you're in NJ, i would install it for you with little $$$
Old 01-26-2017, 05:41 PM   #56
renfield90
The Stig's German cousin
WOW. OP, don't let your "friend" touch your car again. He clearly doesn't know a damn thing about MacPherson strut suspensions, putting the top hats on like that.
The gap in the plates is fine. Almost all designs do that at extreme ends of the adjustment range. What your "friend" did however, putting one top hat at one end of the range and the other at the middle, is totally bonkers, especially since he didn't have alignment tools; and it's double bonkers since the top hats are oriented incorrectly. He pretty much just gave you a random ass alignment...emphasis on the ass.
Do not bother with an alignment until you've corrected the orientation of the top hats. I would go ahead and move the right adjustment to be about equal with where the left is.
The Following User Says Thank You to renfield90 For This Useful Post:
***NEED SOME HELP IN THE NEXT FEW HOURS IF POSSIBLE??*** NorCalGirl Northern California 1 01-21-2015 06:39 PM
Help installing coilovers eSOLOR Northern California 13 12-16-2014 01:51 AM
Installing Coilovers in Las Vegas bobsacamenoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-09-2014 10:14 PM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 02:08 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 10:10 AM
