CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 01-18-2017, 07:54 PM   #1793
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Originally Posted by ATL BRZ View Post
Removed the stock fuel rail covers
Replaced with Velox units, saving 4 pounds from the top of the engine.
The injectors and HPFP are now exposed and can be easily seen/inspected, which I kinda like.
Why not just remove it all?
Cartman is offline   Reply With Quote
Old 01-19-2017, 11:05 AM   #1794
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The car won't run without the passenger's side bracket grounding the ECU to the block. Driver's side is there just for aesthetics and consistency.
Old 01-19-2017, 09:42 PM   #1795
Cartman
Cartman's Avatar
I've run mine without both for close to 2 years... The bottom bolt is enough to ground the ecu
Old 01-20-2017, 03:26 PM   #1796
ATL BRZ
ATL BRZ's Avatar
Yep I learned that the hard way by forgetting about the bottom bolt. I like having all three points on the ECU secured and the aluminum is so light that to me, it's worth having beyond just cosmetic reasons.
Old 01-20-2017, 03:56 PM   #1797
Cartman
Cartman's Avatar
Its a plus to have it secured, I ended up installing a small bracket that goes from the front hole to the engine... I felt that having only 1 bolt holding the ecu with all the tracking it would eventualy loosen.
The Following 2 Users Say Thank You to Cartman For This Useful Post:
ATL BRZ (01-20-2017), Bramick (01-21-2017)
Old 01-25-2017, 07:57 PM   #1798
ATL BRZ
ATL BRZ's Avatar
Got bored and took some new photos.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (01-25-2017), Teseo (01-25-2017), TeutonicShift89 (01-26-2017)
Old 01-25-2017, 08:11 PM   #1799
Pat
Pat's Avatar
Drives: 2023 BRZ
I love this build. Great work all around.
The Following User Says Thank You to Pat For This Useful Post:
ATL BRZ (01-25-2017)
Old 01-25-2017, 08:30 PM   #1800
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
What are you shooting the photos with? It's a DLR check on getting a polarizer filter. You can remove the reflections from the car.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 01-25-2017, 08:35 PM   #1801
ATL BRZ
ATL BRZ's Avatar
My two year old Nexus 6P
The Following User Says Thank You to ATL BRZ For This Useful Post:
Bramick (01-25-2017)
Old 01-25-2017, 08:41 PM   #1802
Teseo
Drives: frs
Future plans for it, maybe FI this year?
Old 01-25-2017, 08:42 PM   #1803
Bramick
Bramick's Avatar
That's what I use too
Old 02-01-2017, 01:23 AM   #1804
ATL BRZ
ATL BRZ's Avatar
Swapped my Velox hood vents out with the slanted version 2 units.
It's a subtle change but it definitely looks more aggressive with these which have less overall louvers and an inward angle to them. I like these much more than the originals.
Bramick (02-01-2017), GTHachiRoku (02-01-2017), Teseo (02-01-2017)
Old 02-01-2017, 01:55 PM   #1805
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I learnt that one the hard way! haha
Old 02-01-2017, 02:44 PM   #1806
ATL BRZ
ATL BRZ's Avatar
So did I. lol
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
