Old 05-07-2015, 03:15 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ATL BRZ View Post
Anyone with aluminum rings have issues with them corroding or sticking to the hub/rotor? Any tips or tricks to keep them from corroding and sticking?
Sand paper, then anti-seize.
Old 05-07-2015, 03:41 PM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by DuMa View Post
it distributes stress and forces across the hub/studs and the wheel/lugs evenly on bumps and dips rather than just the lugs/studs
Negative ghost rider.
They help those who aren't careful mount the wheels correctly to eliminate vibrations. I run them on some wheels and don't on others, but it's out of laziness not a perceived benefit.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-07-2015, 03:42 PM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by wparsons View Post
No they don't. If they were actually taking any force, the plastic would be smashed after the first bump you hit.
Have you ever looked at how tiny the lip on the hub is, and how far offset it is from the centerline of the wheel? If you were to set a car down without lug studs in place, but the wheel properly lined up against the hub with centering rings, it would very quickly pop the wheel off the hub long before the full weight of the car was resting on the wheel.
With conical seat lugs, the only way the ring takes any force is if the lugs aren't seated and torqued down enough, or if the studs are bending.
Hey I have cracked both plastic and aluminum ones.
From heat.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
wparsons (05-07-2015)
Old 05-07-2015, 03:49 PM   #32
gramicci101
Off Topic
From heat.
Dave!
How's the world going? I heard you finally sold your BRZ.
Old 05-07-2015, 03:51 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by gramicci101 View Post
Dave!
Nope. Getting ready to but I haven't even posted it for sale yet. If it didn't cost as much to insure as any two of my other cars combined I'd maybe keep it even though I never drive the thing. 4k miles in 1.5 years... 25k miles in 1.5 years before that
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-07-2015, 03:58 PM   #34
gramicci101
Off Topic
That's the damn truth. Of the three cars I insure, this one costs the most.
<30k miles in three years is not bad mileage at all. Hopefully when you do list it, it goes quickly.
Old 04-20-2016, 07:56 PM   #35
Curtski96
Curtski96's Avatar
Drives: Pearl white '13 frs
Ok so from reading the whole thread this is what I got out of it.
The only real reason for getting hub centric rings is if don't have studs in your hub.
Our cars have studs therefore we don't need the rings.
On my Jetta I had to bolt my rims on because my hub just had holes to bolt the rims into.
I'm hoping this is correct???
Curtski96 is offline   Reply With Quote
Old 04-20-2016, 08:49 PM   #36
MrDinkleman
Drives: 2016 Oceanic, "base" model
Without reading most of this thread: yup.
Edit: You might want to add: If you have alloy wheels that use shank style lug nuts, hub centricity helps. You'd be amazed at how easy it is to screw up installing shank-style lugs when the "wheel tech" abuses/misuses an air-impact gun...
MrDinkleman is offline   Reply With Quote
Old 01-18-2017, 06:08 PM   #37
The Sentinel
Project BRZ-Boosted Autos
The Sentinel's Avatar
Drives: MY14 BRZ
Hi guys. I've just put together a video explaining exactly how this works. The answer depends on the type of wheels you have....
[ame="https://www.youtube.com/watch?v=T5jKRLtJUgY"]Do you need Hub Rings / Choosing Lug Nuts - Complete Wheel Fitment Guide - Part 3 - YouTube[/ame]
Check out my ProjectBRZ YouTube Channel and Facebook Page for the latest reviews, guides and information.
The Sentinel is offline   Reply With Quote
Hubcentric Rings Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 06-08-2016 01:42 PM
Aftermarket wheels in Calgary Davetherave CANADA 4 12-03-2012 10:30 PM
Which Hubcentric Rings do I need? RPF1 Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-20-2012 09:56 AM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 07:19 AM
