Old 01-11-2017, 11:36 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Valve adjustment
The lack of information with legible directions and understanding for valve adjustment on the fa20 engine terrible. Can somebody post a video or actual pictures and/or parts required? I'm not interested in tools. From working on my motorcycle we had buckets and shims but on the fa20 it seems a little backwards and confusing.
I really hope builders dont need to keep 50-60 different valve shims instock.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-11-2017, 11:50 PM   #2
The way I understand it, it's exactly the same.
1. Measure and record all clearances.
2. Disassemble
3. Measure and record all shims
4. Mix & match as much as possible
5. Buy new ones for those that don't fit the bill.
Did I miss anything?
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
humfrz (01-13-2017), jcw99 (01-12-2017), Kris86 (02-21-2017), strat61caster (03-09-2023)
Old 01-12-2017, 12:13 AM   #3
Teseo
Drives: frs
2. Disassemble
Rinse and repeat
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (01-12-2017)
Old 01-12-2017, 09:28 AM   #4
GsxrMe
GsxrMe's Avatar
Is our shim supplier only the dealership? Im intrested in a shim kit or something other than measure and wait 2 weeks for a shim.
2014 Subaru BRZ
Old 01-12-2017, 09:49 AM   #5
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Most dealers can get the shims next day, that's typically what we do and they always have the shims either in stock or next day from a local warehouse.
Gear_One_Performance is offline   Reply With Quote
Old 01-12-2017, 09:50 AM   #6
celek
Resident Gear Head
celek's Avatar
There is a cap on the top of the valve in different thicknesses.
you can to fully assemble and measure the clearance between cam and rocker.
Adjust accordingly.
This is one reason why when disassembling the head you should keep the valves springs retainers rocker and cap all together bagged and marked with the specific cam lobe.
If someone is selling heads in parts keep in mind the shims are like $8 each
You could end up spending $200+ trying to reassemble them. Or HOURS!
Personally if someone is selling heads disassembled the value is scrap unless you have the time and a set of GOOD micrometers to measure inside that little valve cap. But time is money
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
GsxrMe (01-12-2017), Williampreza (01-12-2019)
Old 01-12-2017, 11:44 PM   #7
GsxrMe
GsxrMe's Avatar
Aw.. leave it to celek. Thats what im use to. I couldnt find anything that showed a shim on the valve. Thats exactly what I wanted to see. To Celek.
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post:
celek (01-14-2017)
Old 01-12-2017, 11:49 PM   #8
I don't understand. The whole process is defined in the service manual.
Old 01-13-2017, 12:32 AM   #9
Say WHAT ..... ....... manual ......read..??
celek (01-14-2017)
Old 01-13-2017, 12:46 AM   #10
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
@celek: Am I reading you correctly that the shims/caps don't have their thicknesses marked anywhere? YIKES!! I've been putzing with shim systems (over bucket/under bucket/shim as bucket/cap as shim) for a very long time and almost all have been annotated.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 01-14-2017, 06:41 PM   #11
celek
Resident Gear Head
celek's Avatar
There are markings but the thickness is in .02mm increments
I mean you have to assemble it once and measure everything with feeler gauges and adjust accordingly.
Service manual says use micrometers to verify as there things are tiny
The Following 3 Users Say Thank You to celek For This Useful Post:
Capt Spaulding (01-15-2017), Kris86 (02-21-2017), Ultramaroon (01-14-2017)
Old 01-14-2017, 07:07 PM   #12
There is a statistically significant possibility that a shim is out of tolerance. Even if it's tiny, I strongly advise the measure-twice-cut-once approach.
At least measure a few to verify the calibration of your micrometer. That way, when you find something odd the second time measuring the valve lash, you'll know you can trust the micrometer.
If I haven't done a process at least a few times I tend to go overboard.
RCE Tarmac 2 - top nut adjustment milhouse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-24-2025 06:53 AM
PCV Valve Replacement with STI Valve apelpapa Forced Induction 30 06-03-2022 09:23 PM
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 10:26 PM
Camber adjustment ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-04-2014 08:47 AM
Differential adjustment Dipstik-sportech Engine, Exhaust, Transmission 7 07-22-2013 12:16 PM
