Old 06-27-2012, 01:19 AM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
DIY Rear foglight
Hello everyone!
I decided to write a DIY, my first one ever. I guess i just never took time to take detailed pictures of what i do and share with others but i really appreciate the community over here so i decided to use my spare time at home and write this up for folks that need a hand at it!
i am writing this as it goes and will modify it till its fully done up so bare with me for now!
first thing first, make sure you have the following tools:
-Jack
-Jack Stands (please use them for your safety)
-8mm wrench
-10mm wrench
-Flat tip screwdriver
-Hole saw
-Dremel (rotary cutting tool)
-soldering kit
-wire skinners/cutters
-electrical tape/heat shrink
-6mm circle connector for ground and male/female for + on tail light
0. raise and support car
1. start off by removing the two back-up light sockets
2. using your flat tip screwdriver, pry out the pushpins.
[IMG]http://i65.photobucket.com/albums/h219/silverdub/986be***.jpg[/IMG]
3. take your 10mm wrench and remove the 2 bolts seen on the picture below.
4. using your flat tip scewdriver again, pry open gently the two tabs at the bottom of the lighting assembly. this is not easy so be patient, keep in mind that you dont want to break anything on your brand new car!
5. Locate the area that you need to make a hole
6. Source out an old corner light with the bulb and socket. Cut the old corner light and use for template. Cutting the housing will make some plastic dust in the unit, just blow it out through the hole you just made AND the back up lights holes. Do not attempt to open the housing to clean it or i promise it will break!
7. Once the hole is done insert the socket and bulb, skin your wires and test the results.
8. Open the trunk, take the carpet out and then using a srewdriver pry the trunk latch close in order to save your battery life.
9. Remove the drivers side tool tray by grabbing it with two hands and pulling upwards. You will then hear a loud POP but dont worry its normal
10. Now take this piece out by prying out the 3 pushpins and then pulling the piece upwards
11. Now take out the inner side cover by taking out the clips just like in the previous step.
12. Disconnect the trunk bypass switch
13. Disconnect the backup light connector located below the trunk latch hook. Follow the harness to the grommet and pull it put from underneath the car
14. Put the sockets back in the assy and solder 2 very long wires approximately 5 feet long. Then remove zip ties from the harness and feed a steel wire starting from the connector. You could also just tape them around the harness. When you are done feeding the wires in the harness put back new zip ties in the exact same location.
15. Install the lighting assembly and feed the harness the way it was. Make sure the plastic protection is place like the picture below. Then get back in the trunk and cut the ground wire to the desired lenght and hook it up to the oem grounding point where the connector is located.
16. Remove the drivers side tail light and skin a small piece of the green/yellow wire and install a short wire and connector. This way, your tail light will be removable in the future without having to cut any wires. Once hooked up protect your connector with tape or something simillar.
Now put everything back together, turn your headlights on and enjoy!!!
Silverdub is offline   Reply With Quote
The Following 24 Users Say Thank You to Silverdub For This Useful Post:
5th 86 (05-19-2013), benjoke (06-30-2012), cmspooner (06-27-2012), Dadhawk (06-27-2012), FLYFISHR (09-30-2013), FTEIGHTSIX (06-29-2012), GregV (08-22-2012), Guff (07-02-2012), Gunman (05-20-2013), jacobzking (06-18-2013), Jamifra (06-27-2012), Jayp (06-28-2012), kwood9000 (08-23-2012), LeeMaster (02-14-2013), Lil Abner (06-27-2012), MannyO (06-28-2012), NickD (06-27-2012), rcm47 (06-27-2012), Sall (06-28-2012), Sigh-on-Rice (06-28-2012), Slartibartfast (06-29-2012), Texaz Boy (01-30-2014), zex (06-27-2012), ZILLA (07-01-2012)
Old 06-27-2012, 02:14 AM   #2
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
Looking forward to the full DIY
zex is offline   Reply With Quote
Old 06-27-2012, 02:58 AM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 06-27-2012, 01:13 PM   #4
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Just updated point 5 to 7 as promised!
The Following 3 Users Say Thank You to Silverdub For This Useful Post:
Dadhawk (06-27-2012), Freeman (11-19-2012), percyng (06-27-2012)
Old 06-27-2012, 06:47 PM   #5
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
I'm very glad to see you using an OEM twist style! I have mine sitting in front of me, and plan to do this next week.
Lil Abner is offline   Reply With Quote
Old 06-27-2012, 07:03 PM   #6
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Just finished the write up! I hope you guys have as much fun as i did doing this and that my write up helps you out!
Max
Old 06-27-2012, 07:06 PM   #7
Lil Abner
Question on the brightness. Looks like the fog lights are a 921 bulb. You used a 194/168 bulb for the fog. Have you tried a 921 in the fog housing? Or is it bright enough?
Old 06-27-2012, 07:37 PM   #8
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
It is a 194 but i find it bright enough, if not i will switch the bulb to an LED 194. Keep in mind that this is what i had on hand this morning. You could use which ever bulb you want to make it brighter!
Old 06-27-2012, 09:54 PM   #9
roguetadhg
White Paper Connoisseur
Drives: 2008 VW Jetta
Just to confirm: These function as rear fog lights, that turn on when the front fogs are used? From following the directions it seems they're always on?
Where did you out-source the light socket from?
2003 Toyota Corolla
2003 Toyota Corolla
2009 Mazda RX-8 R3
2008 VW Jetta Wolfsburg
roguetadhg is offline   Reply With Quote
Old 06-27-2012, 10:56 PM   #10
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
where did you get your connector for the rear fog light?
Furtive is offline   Reply With Quote
Old 06-28-2012, 01:52 AM   #11
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Soldering>Crimping. Glad to see someone else doing it the good way.
Thongpocket is offline   Reply With Quote
Old 06-28-2012, 10:31 AM   #12
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
No they turn on with the headlights. As soon as i get the oem front fogs and arm switch i will add another wiring option.
Old 06-28-2012, 10:32 AM   #13
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
You mean the bulb and socket? Off an old corolla corner light.
Old 06-28-2012, 11:19 AM   #14
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
i love this forum
Sall is offline   Reply With Quote
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 02:19 AM
rear seats? EJ20 BRZ First-Gen (2012+) — General Topics 67 11-12-2012 08:15 PM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 01:47 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 03:08 PM
