Old 02-20-2013, 03:49 PM   #15
TRD_86
Drives: 2013 86 white
Does your setup has any poked issue? I often see 9.5 require approx @ +45 to fit flush for rear tires size up to 255 & 265 w/o poking.
TRD_86 is offline   Reply With Quote
Old 02-20-2013, 03:56 PM   #16
kimchangil424
kimchangil424's Avatar
Drives: Raven FRS
It definitely pokes in front a bit. It's not that bad though. I was considering a 255/35/18 but thought it might rub. I would have preferred a wider setup as well since the rim is a 9.5. The rear is not poking out much. Sits pretty much flush.
kimchangil424 is offline   Reply With Quote
Old 02-20-2013, 04:22 PM   #17
stilletto
Drives: 2008 Mitsubishi Eclipse GS
Looks GREAT! Fitment appears to be spot on.
stilletto is offline   Reply With Quote
Old 02-20-2013, 04:24 PM   #18
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Keep those they look great!
Old 02-20-2013, 04:35 PM   #19
kimchangil424
Drives: Raven FRS
Thanks guys.
Old 03-13-2013, 12:54 PM   #20
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory
http://tinyurl.com/86wheels
Old 06-16-2013, 12:57 AM   #21
abling2
Drives: toyota gt86 firestorm red
pls help
my set up is 255/35/18tires with work emotion cr kai KIWAMI 18x9.5 +38 offset.. Im lowered on H&R super sport lowering springs...Im also running a 3mm spacer in the front otherwise the wheels will rub on the struts... what can I do to push it back inside and not stick out(poke)... I know coilovers but I have no money for it right now... I also did my research wit camber bolts and camber plates. so which one is it gonna be the camber bolts or camber plates I should use? or both? if camber plates can they be use on stock struts/shocks? thanks
abling2 is offline   Reply With Quote
Old 06-16-2013, 01:04 AM   #22
Steve
Steve's Avatar
Drives: 6MT
adding more negative camber will reduce poke
but im fairly sure when using camber bolts, inside clearance with the strut will be lessened and therefor cause the rub your already running a spacer to avoid
not sure if camber plates will also cause the same inside clearance issue aswell
Steve is offline   Reply With Quote
Old 06-16-2013, 01:07 AM   #23
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
Camber plates will help out. But camber bolts are a no go.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 06-16-2013, 10:00 AM   #24
wparsons
wparsons's Avatar
I don't know if any of the camber plates will work with stock diameter springs, but if they will then that's your best bet. I'm not sure if you'll get rid of all the poke, but you'll get rid of some for sure.
As said above the camber bolts will just end up putting the tire back into the strut.
As an aside, didn't you see the amount of poke coming from a 255 on a 9.5" +38 wheel up front?
flickr
Old 07-10-2013, 02:33 PM   #25
DarrenDriven
NW Region Moderator
Combined another topic about same wheels with same specs.
Added to the Wheel Directory:
Old 01-03-2017, 07:00 PM   #26
cjopant
cjopant's Avatar
Drives: 2015 Subaru BRZ
I won't be putting them on until the snow disappears, but these arrived over the weekend:
18x9.5 +38 all around.
Been a long time coming. Could not be more stoked for spring!
cjopant is offline   Reply With Quote
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 06:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 05:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 07:00 AM
WTB: Work Emotion Ultimate Kiwami Wheels Center Caps hanabie Want-To-Buy Requests 0 10-25-2013 07:34 PM
WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW RavSpec Wheels and Tires 14 12-01-2012 01:26 AM
