#15 | |
Drives: 2016 Toyota 86 GT (Auto)
A Couple more questions Please, 1- How much HP should I expect to get with Cosworth Stage 2.3 (1.3 + 2.0) and a tune for (95 RON 91 US Octane)? And are you going to release a stage 3 with a forged internals and smaller pully?? |
#16 | |
Drives: blue - Cosworth SC stage 3.0
1st thing to say is any power over 280Bhp is playing with fire on stock internals some folks get away with it but its a lottery as to whether your particular set of rods will go pop or not so yes if you want 330 bhp / 300whp then it best to replace the airbox with a larger filter element part if you can find a larger diameter or more free flowing throttle thats not very overpriced ( cheapest I've seen is $1000.....) then go for it as it will pay dividends and yes a 1320 will come on boost earlier than a 900 unit, its bigger but the 900 can be spun faster to compensate |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | UNREAL (01-02-2017) |
#17 | |
a stage 2.3 on 95 RON should make about 270Bhp and we plan to release a forged bottom end very shortly along with a smaller pulley |
| The Following 4 Users Say Thank You to Matt@Cosworth For This Useful Post: |
#18 | ||
those are the most expensive 56 WHP ever... around $268 per HP... As stage 2.3 costs a whooping 15K USD from your certified dealer in Bahrain!!! For the forged internals... when? approximately... Many thanks for sticking with me and answering my questions
#19 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#20 |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
I just got an Edelbrock kit installed and while i can't comment on the technical aspects i can give you my views on the kit so far. I've run it for about 700 miles so far.
1. I really like the look, i didn't want something OEM looking. I wanted people to notice that i had something different. 2. Currently not on the Edelbrock CARB tune. Thats the tune that comes with the kit and is rated at around 240-250 whp. 3. On the Delicious Flash n Go tune being custom tunes by Zach from Delicious tuning, I'm expecting to hit probably 270-280 who after the tune is complete. 4. LOTS of low end torque on this kit. I've had to learn to feather the throttle a bit when i get going in first gear. 5. Gas mileage went down only slightly from 29 mpg to about 26 mpg. 6. The build quality is solid, while there were a lot of little parts, the kit itself is super solid from what i could tell. I'm currently running 91 California Shell. But i know people have been able to hit about 300hp on this kit running E85. If you do go that route, you WILL need bigger injectors which can be quite costly. Hope this helps
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#21 | |
Drives: GT86 Harrop S/C
Last edited by Bfranklyn86; 01-03-2017 at 06:32 AM. Reason: Didn't read his signature |
#22 |
Drives: Honda Accord Euro
While the initial OPs question is of course valid and interesting, I would like to introduce a thought about the OPs goal of "300 HP". This is of course not a "problem" only here, but overall. By wanting just a nice number for not a particular reason other then "I have 300 HP bro" is so wrong on so many levels. But lets say our brain is playing tricks and just want a nice number. How about this? Horsepower is a retarded ancient unit same as inches and so, why not to opt for civilised target of 200 kW? 200 kW is very nice number as well, is a normalised unit and is 268 HP. You have a nice number, on better units and you can keep you internals and money significantly more save.
How about that?
| The Following 4 Users Say Thank You to JDM4E For This Useful Post: | 86 South Africa (08-04-2017), funwheeldrive (01-03-2017), new2subaru (01-03-2017), UNREAL (08-20-2019) |
#23 |
Lowly Cartuber
yeah we'll see. I'm gonna dyno it after the tune is finished.
#24 | |
and probably the reason the kit is a lot in Bahrain is the the exhaust cost if you leave the stock manifold on it and fit a decent catback of at least 2.5" diameter with all straight through silencers you'll still hit 270Bhp on 93 and 260 on 91 we hope to have the uprated bottom end for sale about March time |
| The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post: |
#25 |
Drives: 13' Satin White Pearl BRZ
I know the OP hasn't asked but have you looked at the Kraftwerks SC? The ONLY reason I bring this up is because if you have an issue with any other S/C (that I have found) your stuck on the road. With the Kraftwerks, its run off a separate belt, so if its not working its a ton of dead weight, but you can get home and not need to be towed.
Just a thought.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
| The Following User Says Thank You to Chronology For This Useful Post: | UNREAL (01-03-2017) |
#26 | |
| The Following User Says Thank You to weederr33 For This Useful Post: | UNREAL (01-03-2017) |
#27 | |||
The number produced by stage 2.3 (91 Octane) is embarrassing... Very embarrassing, no way around it, I was hoping for something better... at least 230-240 WHP. Quote:
2- Wow 270-280 on 91 Fuel and on stock internals and normal engine compression? that would be great, if verified I'll go for E-Force. 3- for the look part it will go really well with my red Gt 86... I don't mind the look what I do mind (a bit) is the fact it sits the highest among all three. Thanks again Quote:
My ultimate performance goal on this car is 0-100kmh in 5.0-4.8 Sec (Yes I do care about acceleration in a straight line, lots of Highways where I live, I also enjoy the precise cornering-ability on this car and the amazing steering feel too, otherwise I wouldn't go and buy the same car after my "2013 Toyota 86 S" one got totaled while sitting outside my house, now I have a 2016 Nur-Spec Toyota GT86) I feel (Yes gut feeling only, No science) that such number will not be achievable with less than 300WHP.. that's where the 300 came from... add to that in the last 12 years I never owned anything but V8's the reason I jumped to the 86 wagon is the out-of-the-box handling and the size of the after market upgrades available. |
| The Following User Says Thank You to UNREAL For This Useful Post: | JDM4E (01-03-2017) |
#28 |
Your assumption that snapping a belt is the only failure that can happen? Keeping a belt in the car is one thing, trying to figure out a S/C failure at a track or on the side of the road is a different story. With the Kraftwerks, you can pretty much "disable the s/c' by removing the belt. So if you have a critical failure on the S/C (minus the belt) your stuck. I personally don't have the skills or tools to diag that type of failure and would require me to take it to the shop, id rather drive my car then have it towed.
| Harrop TVS86 STi BRZ tS | kuczynskika | Member's Car Journals | 255 | 01-24-2022 11:42 PM |
| Harrop vs Edelbrock? Any comparisons? | armstrom | Forced Induction | 51 | 09-23-2019 12:21 PM |
| HELP! Jackson SC vs. Harrop SC | kuczynskika | Forced Induction | 80 | 08-01-2016 06:58 PM |
| Harrop Supercharger | fuddbutter | AUSTRALIA | 32 | 06-10-2016 01:44 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
