Old 01-02-2017, 09:58 PM   #1
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Quick Question on certain tire sizes
In need of Tire sizes for a perfect fit. No wheel popping out of tire.. I was thinking a staggered setup. Front - 18x8.5" +35 Offset. Rear - 18x9.5" +40 Offset. Thanks!!! ALSO. I want to keep the speedo as accurate as possible
AutoNewb is offline   Reply With Quote
Old 01-02-2017, 10:05 PM   #2
swarb
245/35 f
255/35 r
Old 01-02-2017, 10:51 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
Pick a tire, look at the specs chart on tirerack. it lists the actual diameter and tread width and recommended wheel size.
The tire sizes just posted are probably your best options for those wheel sizes, 245/35 is the closest to stock diameter, but even 265/35 ie only about 0.6" taller than stock.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
why? (01-06-2017)
Old 01-05-2017, 02:08 PM   #4
Chris_98
Drives: Scion FRS 2013
New wheels
I need some help with my frs . I'm currently on stock suspension and I'm about to get new wheels? I want to know if 18x8.5 +30 will fit fine with no issues?
If not , someone tell me what 18 inch will fit and tires too.
Chris_98 is offline   Reply With Quote
Old 01-05-2017, 02:14 PM   #5
gramicci101
Off Topic
Posts two and three of this thread will show you what fits and what doesn't, with links to threads where people have wheels in those sizes and offsets. It's very helpful.
http://www.ft86club.com/forums/showthread.php?t=7535
The Following User Says Thank You to gramicci101 For This Useful Post:
Leonardo (01-05-2017)
Old 01-05-2017, 04:16 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I use this Tire calculator. Put in the stock tire size and the new tire size, compare!
http://www.discounttiredirect.com/di...nfoTireMath.do
I LIKE TIRES!
Quick tire question Phantom_9192 Tracking / Autocross / HPDE / Drifting 6 12-02-2016 09:20 PM
Compatible tire sizes Mattstermh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 09-03-2016 08:32 PM
Need help choosing wheel/tire sizes jonbonazza Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-28-2013 09:20 AM
What 18 and 19 in tire sizes will not mess with odometer Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-07-2013 04:59 PM
