go_a_way1
Old 12-29-2016, 02:25 AM   #3865
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by twag4 View Post
I was running flex fuel with a c30, and I snapped a rod. Catastrophic.Engine.Destruction. I will now have to have an engine built, as I was on the ragged edge of what was safe for this engine with stock internals. Keep this in mind when making your decisions. A c38 will provide head room, but to what end? As it turns out, I will be upgrading to a c38 so I can run high rpm. Thought my experience might be useful to you. Good luck!
Thanks... What supporting mods Did you have for your setup? What kind of power were you putting down and what tune were you using?
BR-ZED is offline   Reply With Quote
Old 12-29-2016, 03:25 PM   #3866
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by cgjeff View Post
I'm sure it's been asked and answered, but... which is the best route to go, JR Radiator with oil cooler, or just the oil cooler alone? Not concerned with the extra $$, just want the best option. Running the JRSC C-30, flex fuel kit, Ace 350 Header and full exhaust.
Thanks!!
How often are you tracking the car?
JDMChris is offline   Reply With Quote
Old 12-29-2016, 04:17 PM   #3867
CSG Mike
CSG Mike's Avatar
Thanks!!
Primarily Tracking/racing the car? Standalone oil cooler.
Primarily street driven? Dual radiator/oil cooler.
Both are in stock!
cgjeff (12-30-2016), CxG (01-18-2017)
Old 12-29-2016, 04:19 PM   #3868
Reamer
Drives: 2015 FRS
Both are in stock!
If Jackson Racing's track car is using the rad/OC combo, why is it recommended to run a dedicated OC setup?
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 12-29-2016, 04:46 PM   #3869
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Our T4 NA car has the Dual Radiator Oil Cooler installed. Our Supercharged STU car is running the Track Oil Cooler.
When you increase horsepower, Oil Temps go up more. If you have a dedicated supercharged race car, or are tracking the supercharged car frequently, you would benefit from the Track Oil Cooler, especially if you live in warmer climates.
If you daily drive the car and occasionally track the car, the Dual Radiator/Oil Cooler would work great as well. If you live in colder climate areas, this would also be a good choice as well.
Picking which is right for you is dependent on the duties of your car.
Jackson Racing
-Chris
Jackson Racing is offline   Reply With Quote
The Following 5 Users Say Thank You to Jackson Racing For This Useful Post:
cgjeff (12-30-2016), CSG Mike (12-29-2016), CxG (01-18-2017), Reamer (12-29-2016)
Old 12-29-2016, 04:50 PM   #3870
Reamer
Drives: 2015 FRS
Jackson Racing
-Chris
Ah, I didn't know the T4 car was NA, thank you for the clarification. This is good to know since my (non-existent) track car will stay NA and my daily can keep the combo when I eventually SC it.
Old 12-30-2016, 12:23 AM   #3871
twag4
Drives: frs
My failure wasn't tune related, I believe it was oil pressure related. Pretty sure I spun a rod bearing that caused the rod to break. I was greater than 350hp to the wheels. JR oil cooler, catch can, full exhaust, fluid damper, fuel pump and injectors, on 5w30. If you aren't willing to deal with a catastrophic engine failure, rethink high boost &/or e85. I personally always felt this was inevitable, just thought I would get more time out of my setup.
twag4 is offline   Reply With Quote
The Following 2 Users Say Thank You to twag4 For This Useful Post:
BR-ZED (12-30-2016), CxG (01-18-2017), funwheeldrive (12-30-2016)
Old 12-30-2016, 01:17 AM   #3872
cgjeff
Drives: 2015 Scion FRS
Both are in stock!
Definitely a daily driver, with the possibility of a track day a couple times a year... at most. I do drive the car pretty hard, and noticed some power drop off in the Summer months. I live in Oregon, so Summer Temps aren't brutal, but figured it sure can't hurt to have some additional cooling. Sounds like the Rad/Cooler combo is the best option. Thanks guys for the advice!!
cgjeff is offline   Reply With Quote
The Following User Says Thank You to cgjeff For This Useful Post:
CSG Mike (12-30-2016)
Old 12-30-2016, 03:58 AM   #3873
CSG Mike
CSG Mike's Avatar
Yup, that's what I'd go with. Let us know when you're ready for yours!
cgjeff (12-30-2016)
Old 01-06-2017, 11:12 PM   #3874
86Tony
Drives: 2015 AOZORA EDITION
what would be the best exhaust setup for c38? 2.5, 2.75 or a 3in system?
86Tony is offline   Reply With Quote
The Following User Says Thank You to 86Tony For This Useful Post:
NLS8520 (01-06-2017)
Old 01-06-2017, 11:42 PM   #3875
VABeachBRZ
If you're in the market for an exhaust I would just get the 3in OP/FP and a 3in CBE. but it will be stupid loud.
VABeachBRZ is offline   Reply With Quote
Old 01-07-2017, 01:15 PM   #3876
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
We can catch up and you can experience this setup yourself. Sometime after all this snow/ice stuff
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
CSG Mike (01-08-2017)
Old 01-08-2017, 01:06 PM   #3877
BR-ZED
BR-ZED's Avatar
Anyone with a JRSC car in the MD / Northern VA area? Would love to check it out in person and get a ride in it! Please PM me or just post up here. Thanks!
Old 01-08-2017, 04:13 PM   #3878
VABeachBRZ
I do! I'm running the c38. I'm in Ashburn.
The Following 4 Users Say Thank You to VABeachBRZ For This Useful Post:
BR-ZED (01-09-2017), CxG (01-18-2017), tCsonfrs (01-15-2017), VR4Jr (01-12-2017)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
