Old 11-26-2013, 11:49 AM   #15
evomike
Drives: frs
if the check engine light is on the trac light will come on almost all the time on toyota products
evomike is offline   Reply With Quote
Old 11-26-2013, 02:40 PM   #16
zlegend
yee
zlegend's Avatar
Drives: mehhhh i lost count.
When I checked my codes I had a couple saying the car was running to rich , the code c1201 might be your spark plugs? Did you have more the one code pop up when you checked?
zlegend is offline   Reply With Quote
Old 11-26-2013, 03:56 PM   #17
Mr.EvoMR
Mr.EvoMR's Avatar
Drives: 2013 Scion Fr-s
My Traction Control Light has been on before the CEL ever came on. Meaning about 200 miles into the car it popped up and i could feel that i lose grip on the road. Now at stops the car idle's, then the CEL pops up...im just putting my 2 cents in, have gone to dealer with no help, they act as if they are completley lost...
Mr.EvoMR is offline   Reply With Quote
Old 11-26-2013, 11:16 PM   #18
zlegend
yee
zlegend's Avatar
what mods do you have on the car?
Old 11-28-2013, 10:49 PM   #19
Mr.EvoMR
Mr.EvoMR's Avatar
Just a Injen Air Intake...
Old 11-29-2013, 01:33 AM   #20
zlegend
yee
zlegend's Avatar
maybe try putting stock intake back and reset your ecu to see if that helps?
my aem intake was the problem and since ive gone back to a stock intake no cel light or traction light has turned on.
The Following User Says Thank You to zlegend For This Useful Post:
Mr.EvoMR (11-30-2013)
Old 12-01-2013, 03:25 PM   #21
Cal3000
Drives: Panda FR-S
Try disconnecting the battery for 15 mins then reconnect. It hasn't popped back up since I did that.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 12-04-2013, 02:03 AM   #22
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Originally Posted by Cal3000 View Post
It is a C1201 code that was detected from my ECUtek software. Sorry I didn't post it before. It comes on for about 50 miles, then it shuts off. When the light is on, the traction control does not work. Then comes back on like 500 miles later. Stays on for 50 miles and shuts off again.
Ah, another FI owner with the C1201 code. I had this on the AVO kit as well. It shows as an ABS related fault, but that makes no sense. My running theory is that C1201 is a 'cry for help' DTC relating to excessive oil temp or some other issue relating to high load and stress on the engine which can be caused by, among other things, a supercharger or turbo kit setup. On the other hand, it could be an ECU-related issue.
For me, ECU resets would temporarily remedy the issue, but it always came back for me (before my car was warrantied).
Have you had the car warrantied yet at all? And what is your approx. VIN/build date?
vubaru is offline   Reply With Quote
Old 06-26-2014, 11:11 PM   #23
SPCorBUST
SPCorBUST's Avatar
@Cal3000 was this ever resolved?
SPCorBUST is offline   Reply With Quote
Old 06-27-2014, 02:13 PM   #24
WNDSRFR
Drives: FR-S,GTI
This same thing happened to me after I installed the Phantom ESC without a tune.
What happened is that if you have a CEL lit then the traction control light lights to indicate that you have another CEL. You need to clear the code and the traction control light will go out until you get another CEL.
I guess what I'm saying is that if you have multible CEL's, the traction control lights because there is only one CEL light.
Either fix what is causing the CEL in the first place or tell the tune to just ignore it.
Old 06-27-2014, 03:30 PM   #25
andrew20195
Drives: 2013 Subaru BRZ
That's not an accurate statement. What happens is that some problems that set CELs may interfere with the traction control system, and when they occur, the VDC control module will store an ECM fault code and illuminate to let you know you have no VDC/TCS.
andrew20195 is offline   Reply With Quote
Old 06-27-2014, 03:46 PM   #26
CSG Mike
CSG Mike's Avatar
The TC lgiht comes on to indicate limp mode, not a second CEL.
Old 12-25-2016, 06:20 PM   #27
Rivera12
Drives: Problem with the light check engine
P0018 saves q código es ese
Rivera12 is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 05:32 PM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-05-2014 12:27 AM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 06:18 AM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 05:08 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
