Old 12-16-2016, 12:40 PM   #1
redwing634
Drives: 2013 Scion FR-S (Firestorm)
After some cold weather, the passenger window no longer works
It's also stuck in the "door open" position (where the window goes down just slightly). I've warmed up the car in the garage and the window doesn't do anything. It seems stuck in this position. Has anyone experienced this and knows a fix?
redwing634 is offline   Reply With Quote
Old 12-16-2016, 12:54 PM   #2
http://www.ft86club.com/forums/showthread.php?t=97982
Old 12-16-2016, 12:59 PM   #3
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Hold the switch for that window all the way down (window "down" position) for 10 seconds. Then hold the switch in the "window up" position for 10 seconds. This will reset the window motor settings and it should work fine after.
Same fix works for the driver's side. Do this after every time the window freezes in the future.
It is a common issue, and my windows have done it at least once per season since I got the car.
You're welcome.
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following User Says Thank You to SLVRSRFR For This Useful Post:
humfrz (12-16-2016)
Old 12-16-2016, 08:02 PM   #4
I'm sorry, redwing634, but you get the of the day for not
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
The cold weather is here... echo419 Cosmetic Modification (Interior/Exterior/Lighting) 1 11-17-2015 10:28 AM
Power window fault in cold weather Suberman Issues | Warranty | Recalls / TSB 5 01-09-2014 10:24 AM
e85 in NY cold weather whitefrs Forced Induction 5 12-10-2013 10:52 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
