#15 |
Well now, Packofcrows, that may have worked for you ....... however, IMHO there is no reason to change the oil in this MT for several 10s of thousands of miles.
Ohhhhh........I don't mean to start up this debate again ...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (12-14-2016) |
#16 |
I think that 4 and 6 use the same syncros so you need to spin them or rev match before it will slide in. Your feeling of being blocked out is pretty much what's happening. User error.
#17 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
This car has a wimpy engine with basically no torque, needs high rpms.
Any driving rpm under 2500 is useless...even on a level road. I do understand wanting to downshift from 6th to 4th. Some months ago I was driving at about 50-60mph in 6th gear, wanted to pass a car on a two lane. Downshifted from 6th to 5th and almost got killed trying to pass. Ever since then I downshift from 6th to 4th at those speeds...if I need the power. |
#18 | |
2. Unless you're very comfortable double clutching, don't skip gates downshifting. Spread the work of spinning up the input shaft across all the gears evenly. 3. At 60 mph, fourth gear puts you in the flat spot of the hp curve. Don't be afraid of dropping into third. Wring that bitch out. 4. When at highway speed, practice downshifting into 4th and 3rd. Note the engine RPM. Then, if you choose to double clutch, get your input shaft spun up above that speed. That way, the input side will sink into the target gear.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (12-15-2016), strat61caster (12-15-2016) |
#19 | ||
Drives: '17 86
| The Following User Says Thank You to cat94 For This Useful Post: | Tcoat (12-15-2016) |
#20 |
OP, are you rev matching these down shifts?
I shift from 6th to 4th a lot, especially on the highway when I pull out to pass someone, but I can't say I've ever done it without rev matching. I can't imagine the car being too happy about it without a throttle blip. Edit: I just went out and tried it without a throttle blip. Worked just fine. Are you jamming the gate? Last edited by Tokay444; 12-15-2016 at 10:21 AM. |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Tcoat (12-15-2016) |
#21 |
Drives: '13 FRS - STX
It's not a double clutch if you don't.
#22 |
Drives: Scion FR-s, xB, iA, Silverado Z71 4
I shift from 6th to 4th all the time in the short passing zones on all these KY twisties on my daily commute. Never had an issue. Maybe 110k miles have loosened it up or something.
| The Following User Says Thank You to LotsaMiles For This Useful Post: | Tcoat (12-15-2016) |
#23 |
As discussed earlier in the thread there is nothing wrong with the two gear downshift and there are certainly times when it is needed. Cat just isn't there yet with his experience and may very well be driving at revs and in situations where it just isn't required.
#24 |
Drives: 2013 Pearl White 6MT
I find hat shifting from 6th to fith is a little notchy, however if i shift out of 6 then watch the revs and shift to fourth I have no problems.
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#25 | |
Drives: '17 86
Sounds about right to me. I'm just trying to get an insight into what to and not to do/how to do things correctly. |
#26 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
The transmission is definitely a bit rough and notchy. It'll get better over time. Not sure if fluid change helps or not, I changed to Motul around 4k miles and I think it helped. A heavy shift knob also makes it feel better. |
#27 |
Drives: 2013 Scion FR-S Series 10
How are you gripping the shifter?
I would say you are hitting the gate. If I try to grab the shifter in my palm and drag it out of gear, then move it to the lower gear, I usually get a very vague feeling and lose where I am. I would say that is true with any gear. The exception to this is anything down to 2nd because of its location. I don't know how the '17s are, but if I want to do a 6>4, I would push it out of gear with my palm, let it center itself, then with my pointer, middle and ring finger, just apply moderate pressure on the front of the shifter and it should slip right into 4th. Now, I have a 2013 with 41K miles. When I tested a new 2016, the shifter was tough as all hell. It'll loosen up. But, the 2017s have some transmission changes, so maybe what you are experiencing is the new normal. Basically, just let the transmission do more for you. |
#28 | |
Drives: '17 86
I push straight up into neutral, then straight down letting the knob self center. I'll give it another shot on the freeway at higher rpms. And see if I still get a similar feeling |
| Blocking Your TPMS Light | DarrenDriven | DIY (Do-It-Yourself) Guides | 77 | 03-30-2017 12:18 AM |
| Dealers wrongly mounted your front plate, blocking airflow | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 04-20-2015 02:47 AM |
| Rev match downshift possible with OFT | Simon99 | Software Tuning | 24 | 08-17-2014 05:20 PM |
| Blurring/Blocking Licence Plates in Photos | btoast | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 06-10-2014 01:42 PM |
| downshift to first | swpbrz | Engine, Exhaust, Transmission | 13 | 05-07-2014 09:33 PM |
