#29 |
Drives: FR-S Whiteout
What would be great is some pre and post traction mod videos, data-logs, lap times.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | jeepmor (04-05-2022) |
#30 |
Drives: Subaru BRZ
What about a stock BRZ with camber bolt? I'd like to be able to step on the gas earlier, but don't want the rear to be too soft as the car is already prone to understeer...
Inviato dal mio Galaxy Nexus utilizzando Tapatalk |
#31 | |
Drives: 86 GTS
I have a data log via podium. I'll try and find old lap to compare and we may be able to see something. |
| The Following User Says Thank You to 86•BRZ For This Useful Post: | solidONE (12-07-2016) |
#32 |
Drives: 86 GTS
best i can find to demonstrate:
you can see where full throttle is applied pre and post Pre traction mod: post traction mod: |
#33 |
Drives: 2015 BRZ
#34 |
Drives: 86 GTS
#35 |
Drives: 2015 BRZ
#36 |
Yeah knowing how fast you enter and exit pre and post would help too. Looks good though. I'm assuming the dot on the left indicates where you have applied full throttle in the corner?
Intent > Content
#37 |
Drives: 2014 GT86
From those logs and description of extra stability & ability to open throttle sooner in curve .. that sounds exactly what i got with slight toe-in in rear. BUT! Our cars have toe adjustability as stock, and that doesn't need any extra parts, one can just ask to deal in when doing alignment. About the only thing that this mod might be better for in my eyes is that not-0 toe increases tire wear.
#38 | |
Drives: 86 GTS
The dot is full throttle. There's a million ways to fudge data but it does correlate with what I've been saying. Sent from my iPhone using Tapatalk |
#39 | |
Drives: 86 GTS
MCA Suspension "Traction Mod"
That's a gross simplification of something that is different. A bit like saying you don't need coilovers if you've got a camber bolt. Sent from my iPhone using Tapatalk Last edited by 86•BRZ; 12-08-2016 at 01:48 AM. |
| The Following User Says Thank You to 86•BRZ For This Useful Post: | Sleepless (05-11-2017) |
#40 |
Drives: FRS
Any one know how much this lowers the rear of the car?
#41 | |
It doesn't, it just changes one of the pickup points to reduce rear anti-squat.
#42 |
Drives: FRS
You sure? There are control arms from different manufacturers that have two sets of holes where they attach to the chassis. One set for factory height, one for a 15mm drop. How would changing the pick up point be any different than that? Also, one user already mentioned he had to raise his rear after install...
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
| Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 03:49 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 10:14 PM |
