Old 11-29-2016, 02:11 AM   #183
Nah
Drives: 2013 Scion Frs 6mt
Originally Posted by tyler_win_photo View Post
With the tune, try to go with something like Ecutek and get your car dyno tuned rather than just flashing it with something off the shelf. You'll net more gains. I've seen a peak increase of 7 whp and 6 ft-lbs of torque between a custom tune and an ots flash.
Ehh all in the tuner... but you can never go wrong with a dyno tune. OFT or ecutek
Nah is offline   Reply With Quote
Old 11-29-2016, 10:40 AM   #184
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Originally Posted by gramicci101 View Post
Ok, you're an engineer, so hopefully you can explain this to me. Why is drivetrain loss expressed as a percentage instead of a static number?
Say your car makes 200 bhp, and for ease of math it loses 20 hp (10%) through drivetrain loss. You do some mods to it and now it's making 300 bhp. You're still spinning the same gears at the same speed in the same fluid, so it should still only lose 20 hp, not 30 hp (10%), right? If expressing it as a percentage is correct, why would drivetrain loss go up just because power went up, when the workload to spin all the gears and whatnot hasn't changed?
The simplest explanation is more torque = more friction = more heat = more loss. The percentage comes from the individual friction sources which is a dynamic loss combined with the loss of the energy from all mass of the moving components. Accelerating a mass takes energy, accelerating it faster takes more energy, While the percentage expressed as drivetrain loss is not always 100% accurate it's a good way to oberserve its effects.
I hope that helps, I'm sure more knowledgeable people then me will chime in.
TRAKRAVN is offline   Reply With Quote
The Following 6 Users Say Thank You to TRAKRAVN For This Useful Post:
CSG Mike (11-29-2016), gramicci101 (11-29-2016), justatroll (11-29-2016), Tokay444 (12-01-2016), Ultramaroon (11-29-2016), yelsew (11-29-2016)
Old 11-29-2016, 10:55 AM   #185
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
TRAKRAVN pretty much nailed it.
(note - for the other engineers out there, this is a simplified explanation)
The (static) frictional force is Force = u * N (where u = static frictional coefficient, N = Normal Force).
So the Frictional force (loss) is proportional to the force applied between the two surfaces by the frictional coefficient.
For steel, the static frictional force (lubricated and/or 'greasy') is ~0.16.
So the frictional force (loss) will always be approximately 0.16 times the force applied.
More power from the engine means more force within the trans (gears) but the frictional loss will always be 'in proportion' to the force applied to the mechanism by the frictional coefficient (or about 0.16 = 16%).
Since 'rolling' gears are somewhere between static and rolling friction, it is somewhat less than 0.16 or 16%.
It is more complicated than that as there are pure roller bearings, sliding bearings, and viscous liquids involved, but that is the basics.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
gramicci101 (11-29-2016), Tokay444 (12-01-2016)
Old 11-29-2016, 12:18 PM   #186
Lantana frs
Drives: 13 frs red
In short, baseline and tune on same dyno. Otherwise the delta is questionable.
Lantana frs is offline   Reply With Quote
The Following 3 Users Say Thank You to Lantana frs For This Useful Post:
Old 11-29-2016, 01:43 PM   #187
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The other piece of the puzzle not mentioned is power is work performed/time, so yes, 200 hp at 50 mph shouldn't have any more frictional losses than 300 hp at 50mph, everything *should* be moving at the same speed in that instant, but power is not an instantaneous measurement, but rather a time averaged measurement, and so that 300hp is revving up the system at a quicker rate resulting in a higher absolute power loss.
ineedyourdiddly
Old 11-29-2016, 02:36 PM   #188
Don't forget that to maintain a constant speed at your assumed 50 mph very little of that available power is being used. An 80 hp engine and a 500 hp engine both are producing, what, 7-10ish hp.
strat61caster (11-29-2016)
Old 11-29-2016, 02:58 PM   #189
Lantana frs
Drives: 13 frs red
Imo and from my experience, an otc tune coupled with a good el header will add about 20 horsepower and produce gobs of torque where there was originally none. Makes the car as fast and enjoyable as I could ever want. E85 even better but I wont risk it without a ff setup.
Old 12-01-2016, 11:10 AM   #190
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
Originally Posted by justatroll View Post
Sorry but our cars have ~12-13% drivetrain loss (MT).
Your peak wheel HP shows up as 174.6
174.6 * 1.13 = 197.3 HP
So your engine is outputting right about 200 hp
What am I missing?
(Hint: 'drag power' is way too high @ 41 hp).
41 hp of drivetrain loss on a engine hp of 216 is 19% loss
See what I mean about "tweaking dyno settings" to show power where it isnt?
And thats without being able to see any of the Rotating mass numbers.
This was at an 86 dyno day with 12 86 dynoing the same day, full results in northern California forum. Stock was 136 on same dyno for wheel power.
http://www.ft86club.com/forums/showthread.php?t=109320
GenRuleAThumb is offline   Reply With Quote
Old 12-01-2016, 11:31 AM   #191
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
What am I missing?
...Ah, don't be mad, but you're using the wrong equation there.
you can't multiply the dependent variable by a percentage to get the starting number. Do the proof, that equation isn't reversible. We aren't calculating a 13 percent increase from 174, we're reversing a 13 percent loss to solve for x.
to reverse a 13 percent loss, you would divide the 174.6 by .87, and end up with 200.69 HP, and a reversible, provable equation.
Anyway, you're still right about the 200HP thing. More so, in fact.
Anyway, I'm not here to argue about dyno settings. The only correct answer to any of that is bring a slip. Show the ET. That'll prove a few things, including whether or not a person has the skill to use any of the power their dyno queen makes.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
justatroll (12-01-2016), Tokay444 (12-01-2016)
Old 12-01-2016, 12:09 PM   #192
justatroll
justatroll's Avatar
You are of course correct. But I was able to do the calc I provided in my head to see that the numbers did not make sense.
Doing it my way was close (enough for sanity check) but not correct. Thanks for the correction.
Old 12-01-2016, 12:20 PM   #193
justatroll
justatroll's Avatar
So, since the dyno guy fucked up measuring even a stock vehicle, that gives MORE credibility to your measurement?
I guess since they tested ALL of the cars with the wrong dyno settings so that makes it OK?
The 41 hp drivetrain loss is incorrect, there is no arguing that.
(unless you are dragging a dead horse behind the car of course)
This is not something the dyno can measure, it is a value the dyno operator has to enter (a priori knowledge)
Again, in a stock car we see 174 hp at the wheels (well documented)
The hp rating at the crank is 200 hp
200 -174 = 26hp
26/200 = .13 or 13%
WHY would that change just by adding a few hp at the crank?
Answer - it doesn't.
So IF you measured 174.6 at the wheels, you engine has almost exactly the stock hp rating.
There is just no way to argue that is not the case (other than 'the dyno guy said so')
Old 12-01-2016, 01:11 PM   #194
churchx
churchx's Avatar
Drives: 2014 GT86
justatroll: "in a stock car we see 174 hp at the wheels (well documented)" it's well documented about THIS, very specific dyno? Don't compare results of different dynos. Just don't.
CSG Mike (12-01-2016), GenRuleAThumb (12-01-2016)
Old 12-01-2016, 01:14 PM   #195
GenRuleAThumb
Drives: 2014 FR-S
200 -174 = 26hp
26/200 = .13 or 13%
Im not trying to argue anything was simply adding my results to the thread and sharing more results to the op. Take it with a grain of salt, i am in no way a engineer nor an expert at dyno results. My car feels great and the jump to E85 was a noticeable difference in my experience with my car. I honeslty could care less what a dyno says about my car, i love driving it.
The Following 3 Users Say Thank You to GenRuleAThumb For This Useful Post:
CSG Mike (12-01-2016), justatroll (12-01-2016), why? (12-01-2016)
Old 12-01-2016, 01:14 PM   #196
justatroll
justatroll's Avatar
I am fully aware of the variation between dynos.
I was only using those numbers to calculate drivetrain loss.
BUT the drivetrain loss will NOT vary between dynos.
41 hp of drivetrain loss on a engine hp of 216 is 19% loss - this is wrong.
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 09:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 10:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 06:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 10:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 09:53 PM
