| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: '17 86
Is it better for my tires to be slightly over inflated or under inflated?
Hi,
I have 2 tire pressure gagues (both pretty cheap). One is a slime analog gague ~$3 and the other is an electronic one that came bundled with one of those 12V air compressors. The electronic gauge consistently reads about 1psi higher than the analog one. I know the simple answer is that it doesn't really matter, but I'm curious. If the ideal pressure is 33psi, would it be better to be at 32psi or 34psi? |
#2 |
Drives: frs
Those readings are on "cold" or hot" temp.?
#3 |
That depends whether you prefer wearing out the edges of your tread (low) or the middle (high).
Personally, I'd err on the high side for gas mileage but meh. Unless you measure wear with a tread gauge and keep records it would take a year of driving to notice the difference
#4 |
+- 1psi won't make a difference with the Primacy Tires. Don't sweat it, just get as close to the door sticker PSi as you can.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#5 |
Drives: toyota 86
The recommended pressure on the door sticker is only so the manufacturer can get their desired score for comfort rating on the vehicle. On the standard tyres it makes sense to follow this sticker as a guide but as soon as you change to different tyres I would only follow the tyre manufacturer recommendations
#6 |
Drives: on the highway to hell
You want them to be just like everything else in life and that is 'just right'
#7 |
Drives: 2013 WRB BRZ 6MT
As others have said, +/- 1psi isn't going to make any difference on the street but if I had to choose, I'd rather be slightly over. If under, you can get pre-mature shoulder wear which makes you sad to throw away tires with 4/32nds tread remaining in the middle because you've torn the shoulders off. Ask me how I know:
#8 |
Drives: 2014 GT86
Lynxis: that might be also from pushing on track with suboptimal too less negative camber. I stripped outside thread of tire exactly this way even with stock pressures. It's not as bad now with moderate camber dialed in now (car primarly is dailydriven, not tracked).
| The Following User Says Thank You to churchx For This Useful Post: | Lynxis (11-28-2016) |
#9 | |
Drives: '17 86
These would be cold readings.
Yep, I completely agree. I tend to be curious about these sorts of things and the more you know, the better! What Ultramaroon said about wear makes complete sense though. |
#10 |
Happy motoring!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | cat94 (11-28-2016) |
#11 | |
#12 | |
Scooby***s Guy
Drives: 2019 Impreza Sport - MT
~peaty
2019 Impreza 5 Dr - MT, 2023 Forester Limited - 2001 Miata SE, MT. Kids 2023 BRZ Limited MT, Kids 2015 Crosstrek Premium CVT |
| The Following 2 Users Say Thank You to Peaty For This Useful Post: | jasonojordan (12-01-2016), johl (12-01-2016) |
#13 |
Drives: 2013 BRZ Limited
Overpressure decreases comfort and increases center tread wear.
Underpressure increases comfort, increases outer tread wear, and increases flexing to increase the chance of a pre-mature tire failure. It usually takes a lot of variation to cause bad things to happen, but erring on the high side is the rule in aviation tires. |
| The Following User Says Thank You to HimBRZ For This Useful Post: | cat94 (12-01-2016) |
| Slammed to... Slightly more functional | Cole | Member's Car Journals | 38 | 02-07-2017 03:46 PM |
| Slightly Stretched Tires Concern | TechnoMaster4 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 09-29-2016 05:04 PM |
| Slightly stretched tires = stiffer sidewalls? | ayau | Tracking / Autocross / HPDE / Drifting | 27 | 07-20-2016 03:17 PM |
| FS: Slightly used Greddy Evolution GT CBE | blueap2 | Engine, Exhaust, Bolt-Ons | 9 | 01-26-2016 11:24 PM |
| Throttle slightly sticking? | Dzeremijs | Issues | Warranty | Recalls / TSB | 13 | 02-01-2013 01:27 PM |
