Old 11-27-2016, 02:09 PM   #15
Chronology
Drives: 13' Satin White Pearl BRZ
How much e85 do you have in the tank? You can always flash back see if you have issues. Also, verify your on the high pressure side for your flexfuel fuel line, is the sensor showing you a reading? Can you take a pic of the install? Most tuners won't fail such a basic tune but who knows.
When I went e85 I filled 50/50 and slowly went into a full 75ish mix. I am also on EcuTek so it's auto adjusting for gas types.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 11-27-2016, 03:06 PM   #16
MatthewFRS
CEL + Losing Traction Light on after E85??? (Picture included)
It's only E85. I ran the tank down and filled up with E85
MatthewFRS is offline   Reply With Quote
Old 11-27-2016, 05:53 PM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
There's no mention of Flexfuel here, so guessing a flat E85 tune. A too lean code mean that the trims can't add in enough fuel, which is why it's stalling from the off. The tune is the issue, you just need to make it run richer on E85, it's a simple fix.
.: Stealth 86 :.
Kodename 47 DJ:
Sportsguy83 (11-29-2016)
Old 11-27-2016, 05:55 PM   #18
MatthewFRS
Perfect. I will let my tuner know! Thank you! And you're right I'm not doing flex fuel, just straight up E85 because I have a few stations near me.
Old 11-27-2016, 07:36 PM   #19
ryoma
ryoma's Avatar
if the customer needs to let the tuner know how to tune the car then I would NOT go back to that tuner. you could end up with an extremely expensive repair build
The Following User Says Thank You to ryoma For This Useful Post:
Tcoat (11-28-2016)
Old 11-27-2016, 07:37 PM   #20
MatthewFRS
Yeah I've learned for next time don't worry about that haha. Just going to have him fix what's wrong now.
Old 11-27-2016, 10:21 PM   #21
Chronology
Sorry, I assumed if running e85 some type of GM style fuel sensor would be in place to tell the ecu the actual mix. If the tuner tunes it to e85 and your true ethonal is 70s does a non flex fuel tune work? Would that work the same way as running 91 vs 93?
Old 11-28-2016, 08:33 AM   #22
Kodename47
Kodename47's Avatar
Drives: UK GT86
With different blends of ethanol the fuel trims will sort that out, however this case it's so far out the trims are maxed out. As for timing, you may be fine with E70 or higher running similar timing due to MBT, I cannot fully comment as we don't have E85 here so not tuned for it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-29-2016, 08:23 PM   #23
MatthewFRS
That was the issue! It has been fixed so far and I've not gotten a CEL. Hopefully it stays that way.
Shuddering from rear when losing traction nickmerronesucks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-30-2022 05:32 PM
Car losing traction in corners Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 03-06-2016 07:50 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
