#645 |
Drives: FT86
#646 | |
Drives: FT86
Yep the MAF correction after start tables and load limit tables are not in the standard oft defs. Thet are probably in wayno's defs attached to his post. if you don't do the maf offset tables the car will still idle very high even if you change the idle target tables. however the oft guys do different calid changes to roms so check a few tables in your tune if your using wayno's defs and make sure everything looks ok, if theirs any weird values don't edit your tune. see the romraider tips link below |
#647 |
Ricer
#648 | |
Drives: 2016 Scion FR-S RS 2.0
Sent from my ONE A2005 using Tapatalk
2016 Scion FR-S Release Series 2.0 #170/1000
#649 | |
Ricer
No specific files such as 91, 93 or E85. Just 1 file. |
#650 | |
#651 | |
Drives: FT86
their was no update to the e85 tunes just use the ver 2 e85 tunes if you want to run e85 oft guys are currently testing flex fuel tunes theirs thread on it here so untill flex is released you need to reflash to change fuels |
#652 |
Drives: Whiteout
So according to some posts in this thread the new Stage 2 OFH tune has to be run on 93 oct fuel, but in the release notes in the Stage 2 OFH tune (downloaded from the openflash website) it says to use either 91 or 93 oct fuel. Which is correct?
#653 |
Drives: 2013 Scion Frs 6mt
Those maps are more aggressive so 93 is preferred however, i'm sure ourecu would adjust and pull timing to protect your motor. I'd probably use 93 just to be safe...
#654 |
Drives: Whiteout
Yeah I was on the Stage 2 OFH tune but it just didn't feel right so I just flashed the Stage 2 UEL 91 oct tune instead just to be safe.
#655 | |
Drives: Hyper Blue BRZ
Issue with stage 1 is based on the info provided the map is for EL and most of the aftermarket headers are uel
#656 | |
The OFT UEL tunes are suited for their header & any header that matches their layout (E.G. Tomei UEL or Gruppe-S). Anything else will be off. Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
#657 |
Is it safe to pull like 1 or 2 degrees from 5000 rpm onward as a precautionary strategy? Curious on how much timing you pulled and where?
[ QUOTE=DarkSunrise;2674084]I was curious today and compared the OFH tune vs. UEL v2.076 in RomRaider, trying to see why it was running leaner. I didn't see any changes in MAF scaling, but the base timing, IAT timing compensation, timing advance, intake/exhaust cam advance and AFR targets had all been tweaked. I'm not an expert but the OFH tune appears to be designed to run leaner and with more ignition timing, but also with additional dialing back of timing to compensate for heat/IATs. I ended up taking out a little base timing at medium loads in the midrange and at high loads near redline. Drove for an hour afterwards in 90 F weather. No FLKC and minimal KC (random) so things looked pretty good in the logs. Won't know for sure though until I do some repeated pulls later this week.[/QUOTE] |
#658 |
Similar due to cat less or similar due to the shape
[sQUOTE=alxtheoreo;2804241]Why don't you start with stg2 EL tune. Considering your setup from previous post, your best bet is to get it tuned via ECUTEK or something more advanced/stand alone. The OFT UEL tunes are suited for their header & any header that matches their layout (E.G. Tomei UEL or Gruppe-S). Anything else will be off. Sent from my SM-G930V using Tapatalk[/QUOTE] |
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
