#337 |
Drives: 2013 FRS
Any update on how the new oil pan performed? Any correction to the oil pressure concern? Also how much oil exactly did it add to the capacity? Thanks!
#338 | |
Very interested to see what you come up with for brake ducting. I played with trying to duct my endurance kit a bit but couldn't come up with a path I liked with the large hose. Also interested to hear what you think of the pads.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#339 | ||
Drives: 2015 BRZ
Jake |
#340 |
Drives: 2015 BRZ
The driver is complaining that the car feels very "jittery" over disturbances in the track. Naturally, I'd guess that's due to the fact that the Tarmac 2s don't have a high-speed blow-off, or digressive valving, or however you want to phrase it. Basically, the damping curve is approximately linear. Higher-end shocks actually lower the rate at which damping force rises at higher speeds, which means the car is able to absorb high speed impacts (curbs, bumps, etc) without upsetting the chassis.
So, let's see how that looks in the data. Here's a plot from the MXL2 in the BRZ, showing left rear shock position (on top) and velocity (on bottom). ![]() And, for comparison's sake, here's the left rear shock of a Viper GTS with Penske 8765s traversing the exact same disturbance on the track: ![]() Both graphs are scaled the same in the Y axis, and the X axis lines are 0.5s on both graphs. So you can see the Viper shock gets the oscillation under control much faster and smoother. Not trying to say the answer is a set of $15,000 shocks, but this is a great example of why digressive valving is so important on a track car. |
| The Following 6 Users Say Thank You to GSpeed For This Useful Post: | BigFatFlip (11-14-2016), DarkSunrise (11-17-2016), Jonsey (11-14-2016), Lonewolf (11-15-2016), MaximeT (11-15-2016), Tristor (08-30-2018) |
#341 |
Drives: GT86-ACE-JRZ-RPF1-Essex
Thank you, I want a shock sensor now :/
Great work.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
| The Following User Says Thank You to MaximeT For This Useful Post: | GSpeed (11-15-2016) |
#342 |
Drives: 2015 BRZ
Here's some temperature plots from our sessions last Friday. As you can see, differential temperature is rapidly approaching unsafe levels. Most evident in the longer, first session it ended the 20 minute session at 275°F, after starting at about 110°F.
Considering we're still at stock power levels, this is pretty concerning. We'll need to do something about that. This is also great evidence of why data systems and good sensors are important. Considering this is a lightly modified car, on a cool day, and differential fluid is still reaching 275°F, I'd bet money most people without rear end coolers are toasting their fluid and not even realizing it. It's too soon to say, but it could have something to do with the axle failure issues if the diff is overheating on a regular basis. |
| The Following 11 Users Say Thank You to GSpeed For This Useful Post: | BatStig (11-17-2016), DarkSunrise (11-17-2016), DocWalt (11-17-2016), Guff (11-17-2016), ichitaka05 (11-17-2016), Jonsey (11-17-2016), lamawithonel (11-17-2016), MaximeT (11-18-2016), new2subaru (11-17-2016), TofuJoe (11-21-2016), Tristor (08-30-2018) |
#343 |
JHerbert Racing
Drives: 2013 Scion FRS
Quite concerning. Do you think a high capacity dif cover could solve the issue or are we going to need to go all out with a cooler kit?
#344 | |
Site Moderator
Drives: ichi 86 Project
#345 | |
Drives: 2015 BRZ
Yep. We're going to try and find a way to do a mechanical pump. Electric pumps aren't all that reliable in comparison. |
| The Following User Says Thank You to GSpeed For This Useful Post: | BatStig (11-18-2016) |
#346 | |
Site Moderator
![]() CS-v3 have one too... but not sure it's mechanical or electric pump. |
#347 |
JHerbert Racing
Sorry if I am taking away from your build thread but you seem like the people to ask. I have done some research on the diff matter and found myself with a few questions.
1) At what fluid temperature can damage to the diff occur? 2) What is the optimal operating temperature for 75w-90? I was only able to find this data on Motul 300 75w-90 which leads me to believe any higher that 212 degrees Fahrenheit starts getting dangerous. Is that an accurate statement? PROPERTIES Viscosity grade SAE J306 75W-90 Density at 20°C (68°F) ASTM D1298 0.897 Viscosity at 40°C (104°F) ASTM D445 72.6 mm²/s Viscosity at 100°C (212°F) ASTM D445 15.2 mm²/s Viscosity index ASTM D2270 222 Flash point ASTM D92 200°C / 392°F Pour point ASTM D97 -60°C / -76°F
#348 | |
Drives: 2015 BRZ
Generally the gear manufacturer will provide the operational limits if there are any specific ones. For example, Emco lists a maximum temperature of 330° for 15 minutes, or something close to that (going off memory). Anything above, or longer, than that will alter the case hardening of the gears and can cause permanent damage. Granted, that's an Emco and it's abnormally durable. If our diff never got above 275°, I would be a happy camper. But from the data posted above, I don't think that's going to happen. |
#349 |
Drives: 2023 BRZ
So basically if a normally aspirated BRZ never runs more than 20 minute sessions we shouldn't be too concerned, right? But if we go longer than that it we should consider a cooler?
#350 |
Drives: 2015 BRZ
Yes, that's the gist of it. There are lots of variables like tires, power, outside temp, etc. but generally yes.
| North East Track/AX - what did you sign up for? | dp1 | NY / NJ / CT / PA | 42 | 10-17-2016 11:51 PM |
| Ohio Track Day - Nelson's Ledges 2015 | mcquarrieg | Great Lakes | 24 | 08-04-2015 03:43 PM |
| Bar & Track - 2015 Subaru WRX Review | FT-86 SpeedFactory | FR-S / BRZ vs.... | 71 | 05-26-2014 12:08 AM |
