Old 11-16-2016, 09:06 AM   #1
nammie81
Drives: 2016 frs
wheel spacers question
4mm and 6mm wheel spacers on 18x8.5 +38 wheels
would this be safe to use on the stock nuts
or if anyone has a certain brand they would recommend
nammie81 is offline   Reply With Quote
Old 11-16-2016, 11:05 AM   #2
Icecreamtruk
Drives: Track preped NA FRS
4mm yes, 6mm might be dodgy. I have used 5mm spacers at the track on stock nuts with r-compound tires. If they can handly that, they can handle anything. But there really is barely enough thread, so 6mm might be pushing your luck.
Icecreamtruk is offline   Reply With Quote
Old 11-16-2016, 12:29 PM   #3
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
4mm = No
6mm = No
The stock studs are only safe up to a 3mm spacer.
If you want more, I'd highly suggest buying extended studs.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-16-2016, 12:44 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just got spacers with extended studs. They were only a bit more than just the spacer. Do it right and play it safe.
Old 11-17-2016, 12:10 AM   #5
nammie81
Drives: 2016 frs
i think i will just get extended wheel studs then
Wheel spacers vincelive123 Scion FR-S / Toyota 86 GT86 General Forum 6 01-16-2016 10:55 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 02:35 AM
Wheel Spacers Question bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-03-2014 01:54 AM
H&R Wheel Spacers! vividracing Wheels and Tires 3 06-19-2012 06:11 PM
