Old 04-12-2014, 03:19 PM   #57
cammaxon
Drives: 13 BRZ LTD
1. The JDM BRZ STI uses the SAME Brembos as the 08+ Impreza STI with the bleeders swapped there are no brake bias issues, no fitment issues every thing is copacetic.
2. This is a super easy swap (~4hr drinking beers, eating pizza)
3. This is a super cheap swap (I got EVERYTHING for <$1,300)
4. IF you can't find 08+ rears, the KNS V 2.0 bracket is MINT!
SWAP THE BLEEDERS! a little heat and the come right out.
USE any STI front rotors as long as they are drilled 5x100
USE any STI front calipers
USE 04-07 STI rear calipers with KNS bracket ($250)
USE 08+ rear STI calipers for direct fit
USE 08+ rear STI rotors Drilled to 5x100 (to be compatible with e-brake)
The Dust shields have to be slightly trimmed to fit your new (larger) rotors.
You can get everything except the calipers from KNS Brakes and they guys over there are very familiar with the mod. CALL them if you don't know what you need. They will also make sure your rears rotors are drilled to the right pattern.
cammaxon is offline   Reply With Quote
The Following User Says Thank You to cammaxon For This Useful Post:
Trap63 (04-12-2014)
Old 04-12-2014, 06:03 PM   #58
brz_star21
Drives: DGM BRZ
Originally Posted by 000 Racing View Post
Will a 17" rim fit over these Brembo's.. due to our race rules I have to stay with 17 x 7 but I can get a better offset to keep the spokes away from the caliper??
Stocks will fit but you'll need to run spacers (20mm or 25mm depending on preference should do the trick).
Don't mind the dirt I put the stocks back on before doing a little body work
brz_star21 is offline   Reply With Quote
Old 04-12-2014, 06:51 PM   #59
cammaxon
Drives: 13 BRZ LTD
Originally Posted by spiller View Post
^^ 17s should fit. from memory some of the early GBD Stis came with 17s from the factory. will need the right spoke design however.
so with the installation, you put the RHS caliper on the LHS and the LHS caliper on the RHS? what about the rear?
The rears are good to go. same side as intended
Old 04-19-2014, 12:30 AM   #60
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've just got hold of a pair of GRB STi calipers and from all my research up to now tells me it's a straight forward swap (apart from the bleeder issue). But then I came across this thread and from the OP's magazine pics it shows that they've used some kind of bracket on the front hubs to install the new caliper?
I can't read Japanese so I don't know what it says, but I gather that car had the 277mm front brakes, similar to mine (lower spec AU market 86) as opposed to the 294mm brakes.
Could this be the reason why they've used a bracket to mount the new calipers? I didn't think it would be necessary since I figured the steering knuckles and bracket mounting points are the same across both models. Any comments/advice on this?
@King Tut @OrbitalEllipses @Racecomp Engineering
Fizz is offline   Reply With Quote
Old 04-21-2014, 10:22 AM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't know what that bracket is to be honest. As long as the front calipers are from a 2004 to 2014 STI and the rear calipers are from a 2008 to 2014 STI then they should bolt right on using the STI bolts.
Old 04-21-2014, 11:12 AM   #62
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I did somemore searching and the bracket shown in the magazine isn't actually an adaptor to alter the mounting points. Instead it's simply a brace to stiffen up the mounting points.
Old 10-14-2014, 05:01 PM   #63
sinned706
Drives: White BRZ Limited
Originally Posted by P&L Motorsports View Post
As promised, pictures of the swap! P&L Motorsports SS Brake lines/ STI brembos/ DBA 4000 rotors/ hawk HT-10 pads w/ ARP studs.
Notice 4 bleeders: 2 on top/ 2 on bottom
what type of modifications did you do on the rear to make it fit?
sinned706 is offline   Reply With Quote
Old 10-16-2014, 05:41 PM   #64
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Go to the DIY section and search this out. At least 3 VERY thorough conversations on this
Old 10-16-2014, 09:35 PM   #65
driftlover78
Drives: 99 Golf
translation on google translate
Slit design of the rotor, reproduce those of R205 and RA-R based on the DIXCEL made​​.
Front adopted the HD DAV of FCR (reverse bench), the rear.
Center hat portion is painted in black. (The unpainted case of no hardening)
For this kit, brake hose was prepared color (black) and there is no length to commercial products.
Corresponding model Legacy BM / BR
EXIGA YA4 / YA5
Impreza GH / GR (non-Brembo fitted model)
Forester SH
Kit contents Brembo calipers (FRONT 4POT / REAR 2POT)
Original brake rotor (FRONT / REAR)
Original Stainless steel mesh brake hose (APP Co., Ltd.)
Back plate (FRONT / REAR)
Tie bar (less options available)
Impreza GRB spec C genuine brake pads
Center hub nut
Caliper mounting bolts & Short parts
Orders stop there price (※) rotor quenching
Rotor quenching without stop orders
MX72 pad option price endless Inc.
(Before and after · GRB spec C genuine trade-in pad) stop orders
※ The product AGRESS, partners here, or you can order Subaru dealers across the country, even car shop like.
clear as mud....
driftlover78 is offline   Reply With Quote
Old 11-09-2016, 06:31 AM   #66
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
The rear caliper bolts could be re-used from stock rear calipers for 08+ rear STI calipers swap?
MSTiFK8R is offline   Reply With Quote
Old 11-15-2016, 03:50 PM   #67
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
I thought I saw Japan parts selling STI brakes(F/R) for the FRS/BRZ for about 5000usd.
https://www.japanparts.com/parts/detail/45055
fizzymike is offline   Reply With Quote
Brembo BBKs Announced oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 06-11-2014 11:51 PM
Stock caliper model? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-31-2012 09:41 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 03:06 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
