View Poll Results: Should you drive right away from a cold start?
Yes 79 24.84%
No 145 45.60%
Pizza 94 29.56%
Voters: 318. You may not vote on this poll
Old 10-28-2015, 01:21 PM   #99
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
It was very difficult not to answer "Pizza".
In all seriousness I always wait until RPMs to drop before driving. Then I stay in vacuum until oil temps come up.
MokSpeed is offline   Reply With Quote
Old 11-07-2015, 02:08 PM   #100
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I saw a video recently that said if you are to enter higher revs to start you can warm your engine up faster. I would think this is probably hard on the engine. I will try to find the video to post.
My warm up method is to wait until the idle drops and then drive with the revs below 3,000 rpm until up to temp.
Chad86 is offline   Reply With Quote
Old 11-09-2015, 11:11 AM   #101
LeftLaner
Drives: 2013 Scion/Toyota Ultramarine MT
Thumbs up
I turn the key twice to get all the electrical components going (wait like 20 sec) then turn on the engine. It idles at 1500-16500 rpm first then I wait till it drops to 600-650 rpm and drive....however I do not exceed 3500 rpm because I have noticed a funny noise when driving under load with the engine about 1/4 way warm. I notice that I pull quite a bit at low....maybe the ECU adapted to my different driving habits on a cold start? Not complaining.
LeftLaner is offline   Reply With Quote
Old 11-09-2015, 11:16 AM   #102
Simple! How is this even a discussion? Starting a car in the cold has become a mystery to people?
Old 11-15-2016, 01:48 PM   #103
JohnFAckerman
My car is getting hard to start in cold weather.. what do I do... it is an FRS
JohnFAckerman is offline   Reply With Quote
Old 11-15-2016, 01:52 PM   #104
gramicci101
Off Topic
As in, taking a while to crank before it turns over? It's a 2014? Get a new battery. The OEM battery doesn't have the greatest CCA spec when it's new, much less three years old.
The Following User Says Thank You to gramicci101 For This Useful Post:
JohnJuan (11-15-2016)
Old 11-15-2016, 02:11 PM   #105
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Pizza hit 86 today
The Following 2 Users Say Thank You to bcj For This Useful Post:
go_a_way1 (11-15-2016), Tcoat (11-15-2016)
Old 11-15-2016, 03:05 PM   #106
Pizza hit 86 today
Old 11-15-2016, 03:14 PM   #107
Da Brz
Drives: 2016 Subaru BRZ
Mine, every now and then, takes more cranks to start than normal.
As in, normally it turns over about three times, then starts. Sometimes it turns about 6 times before it starts.
You mean something like that?
Da Brz is offline   Reply With Quote
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 08:15 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 08:02 AM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 11:49 AM
